Question about Epson ACULASER CX11NF All-In-One Printer
Service reqd E511
Have replaced photo con unit still get same messaged. There is a sensor on left hand side (underneath photo con unit) the pcb is cracked, am unable to get replacement cannot find a part number, have spoken to engineer at local epson centre who said I need to call out epson engineer as they can only look at b&w printers !!
Can you help me to locate part ?
  • rab42bank May 21, 2008
    epson ????
  • Epson Master
  • 691 Answers
E511 is a TR0 Sensor Fault. Can be caused by:
Photoconductor Unit
SENSOR TR-0
HARNESS-ASSY XERO
MOTOR ASSY P/R
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
Not really something easy to fix at home.
Posted on May 26, 2008
  • Inky Fingers
    Inky Fingers May 26, 2008
    NEW INFO:
    Look at the bar code label on your PCU unit. If the lot number on it
    (see pic below) is in the range 711 to 78A then the PCU is from a
    faulty batch.
    Returning to Epson for a new one should sort the issue.
Problem in the left side screen
POSSIBLE PROBLEMS.....ribbon cables between main & T-CON PCB, cable between t-con & panel, T-Con PCB & lastly, the panel itself. If panel replace TV!
May 23, 2014 | Televison & Video
After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
Welcome to FixYa, the world's largest product support community.
The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
1. Turn the printer on, and open cover B.
2. Raise the yellow lever inside cover B.
3. Remove the photoconductor unit.
4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
Jun 09, 2011 | Epson Aculaser C1100 Printer
I am getting an error message of E 511 what does this mean and how do i fix it? can it be bypasses? how do i reset the unit? Thanks
Hi Collin,
E511 is a TR0 Sensor Fault. This is commonly caused by:
Photoconductor Unit
SENSOR TR-0
HARNESS-ASSY XERO
MOTOR ASSY P/R
HARNESS ASSY MAIN
PWBA MCU
LV/HVPS
This is not Diy, I've advice you to send the unit to your local Epson Service center.
Hope it may help you.
Have a nice day!
Feb 12, 2011 | Epson ACULASER CX11NF All-In-One Printer
Printer displaying "Service Req E511" and wont print
Error E511 relates to the PCU (not detecting the transfer belt rotating).
This appears to be common. Sometimes the belt can slide on the rollers to the left, thus the square metallic reflective spot on the belt does not pass over the TR0 sensor, no amount of cleaning will cure this, you either need to strip the top cover off hte PCU (6screws) and pull the belt back over to the left or replace the PCU all together. BTW PCU stands for Photoconductor Unit if you didn't know.
Aug 17, 2010 | Epson Aculaser C1100 Printer
Service Req E511
e511 is to do with the photoconductor unit which sits under the top lid
usually detector underneath the photoconductor dirty or the wide rubber belt then runs throuigh the photoconductor is sligthly off to one side
Feb 24, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
Epson CX11NF Error Message Service Req E511
This is from the service manual
Service Req E511
�� Possible parts that caused the error�� Troubleshooting
�� Photoconductor Unit �� SENSOR TR-0
�� HARNESS-ASSY XERO �� MOTOR ASSY P/R
�� HARNESS ASSY MAIN �� PWBA MCU�� LV/HVPSStep Check Yes No
1 Check of Photoconductor Unit attachment
Re-attach Photoconductor Unit.
Does the error recur when the power is turned
ON?
Go to Step [2]. End of
procedure
2 Operation check of Photoconductor Unit
Is the Drum of Photoconductor Unit rotating?
Go to Step [3]. Go to Step [10].
3 Check for dirt on silver seal on Belt in
Photoconductor Unit
Remove Photoconductor Unit.
Turn gear of Photoconductor Unit until silver
seal attached to Belt can be seen.
Is silver seal dirty?
Replace
Photoconductor
Unit.
Go to Step [4].
4 Check of SENSOR TR-0 (TR0 Sensor)
Is SENSOR TR-0 attached securely?
Go to Step [5]. Re-attach
the SENSOR
TR-0, and go to
step [5].
5 Check of dirt and foreign bodies on surface
of SENSOR TR-0
Are there any dirt or foreign bodies on the
SENSOR TR-0 surface?
Clean to remove
any dirt or
foreign bodies,
and go to step
[6].
Go to Step [7].
6 Does the error recur when the power is
turned ON?
Go to Step [7]. End of
procedure
7 Operation check of SENSOR TR-0
The voltage of P416-2 ↔ P416-3 on PWBA
MCU is 5 VDC when silver paper or other
reflective object comes close to the sensing
area of SENSOR TR-0, and is 0 VDC when
the object is released?
Replace PWBA
MCU. (p.404)
Go to Step [8].
8 Check of 5 VDC power supply to SENSOR
TR-0
The voltage of P416-1 ↔ P416-3 on PWBA
MCU is 5 VDC?
Go to Step [9]. Go to Step [14].
9 Continuity check of HARNESS-ASSY XERO
Disconnect the P/J416 from PWBA MCU.
Do all of the wiring below have normal
continuity?
J416-1 ↔ J108-3
J416-2 ↔ J108-2
J416-3 ↔ J108-1
Replace
SENSOR TR-0.
(p.361)
Replace
HARNESSASSY
XERO.
10 Check after replacement of MOTOR ASSY
P/R
Replace MOTOR ASSY P/R. (p.398)
ON?
Go to Step [11]. End of
procedure
11 24 VDC power supply check to MOTOR
ASSY P/R
Disconnect P/J201 from MOTOR ASSY P/R.
The voltage of J201-1 ↔ J201-2 is 24 VDC?
Go to Step [12]. Go to Step [13].
12 Continuity check of HARNESS ASSY MAIN
Disconnect the P/J403 from PWBA MCU.
Is the continuity normal between all terminals
of J403 ↔ J200?
Replace PWBA
MCU. (p.404)
Repair broken
or shorted part.
13 Continuity check of HARNESS ASSY MAIN
Disconnect P/J502 from LV/HVPS.
continuity?
J502-9 ↔ J201-1
J502-10 ↔ J201-2
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
14 5 VDC power supply check to PWBA MCU
The voltage of P410-3 ↔ P410-4 on PWBA
MCU is 5 VDC?
Replace PWBA
MCU. (p.404)
Go to Step [15].
15 Continuity check of HARNESS ASSY MAIN
Disconnect P/J410 from PWBA MCU and P/
J502 from LV/HVPS.
continuity?
J410-3 ↔ J502-3
J410-4 ↔ J502-4
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
May 22, 2008 | Epson Aculaser C1100 Printer
Service reqd E511
I was able to get hold of a schematic diagram to locate the part number for sensor :
part code 2090463 SENSOR TR-0
When I inspected the original part the pcb was cracked therefore the sensor was unable to dectect the 'mirror' which is a silver square located on belt on photo con unit.
If you require a copy of the schematic diagram (pdf) let me know an address to send it to.
Regards
Rob
May 22, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 - E511
The E511 error comes when you power up the printer. The noise of the "warm up" is the black rubber transfer belt on the Photo Conductor Unit spinning through one rev to check for a little silver square on the edge of the belt. You can turn the belt manually to see this square.
If this square is not found, Epson will tell you to throw away an otherwise fine PCU.
Solution:
a) Remove PCU and check the transfer belt for the square. Clean WITHOUT alcohol.
b) check the sensor that reads this square - a small black oblong "camera" in the heart of the printer on the LHS. Clean.
c) If the square is damaged, replace with a piece of tin foil. Superglue on carefully, making sure all the edges are glued but not your fingers!
You don't need to put the new square in exactly the same place, just above or below on the belt is fine.
Nov 01, 2007 | Epson Aculaser C1100 Printer
Epson ACULASER CX11NF All-In-One Printer Logo
6,503 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
