CUSTOMER RUNS OVERSIZE STOCK ( 17" L ), PRINTING LESS THAN 1 SQ INCH, METER SHOWS 2 CLICKS PER COPY DUE TO LENGTH. IS THERE A WAY TO SET TO 1 CLICK / COPY ?
TKS
STEVEC@TUF-TOP.COM
SOURCE: E000001 002 ERROR CODE, HOW DO I CLEAR IT ?
Problem should be checked out by a technician as clearing the error is not going to make a problem go away if it's there (although to you it may appear as if it is), but if you must. You can go into Service Mode (Additional Functions > 2,8 > Additional Functions), Copier > Function > Clear > ERR. Select the ERR to highlight then turn copier on and off using main power switch (on right hand side of copier. Wait 10 secs or so before turning back on).
Posted on Aug 18, 2009
Feb 19, 2017 | Office Equipment & Supplies
Jul 17, 2016 | Garden
Jan 25, 2013 | Office Equipment & Supplies
http://waterheatertimer.org/Auto-circ-manual.pdf
Manual gives instructions for a different timer dial than timer than shows on unit, so they must come with different dials.
Instructions say pegs pulled out = timer on
Conversely, pegs pushed in = timer off
You might be able to hear the pump operating to see if these instructions are correct for your recirculation timer. The kids would love a listening assignment under the sink.
To see images showing how recirculation system operates:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Setting times:
Try 1/2 hour ON in morning and 1/2 hour ON in evening. Warm water will stay in pipe for a while.
Recirculation system with timer costs $10-17 per year to operate, assuming timer runs 1 hour per day with electric prices at 10 cents per kilowatt hour. Operation cost is straight line ... so if timer runs 2 hours per day, cost is $20-34 per year at 10 cents per Kwh.
Water saved might equal 5 gallons per day, or 1825 gallons per year depending on usage. Average water wasted waiting for hot water is 1/2- 2/3 gallon depending on length of pipe. Set a bucket under spigot to test your home when circulation system is not ON.
Cost of water depends on local billing rate. The municipality saves purifying water, pumping water
to your home, and finally pumping and processing sewage drainwater.
If you are on a water well, the pump electricity from saving 2000 gallons a year is a dollar or two per year since water well generally consumes less than 1Kwh per day for ordinary house.
Sep 29, 2010 | Hardware & Accessories
Sep 22, 2010 | Cfm Heating & Cooling
Dec 31, 2009 | Canon imageRUNNER C5180 Color Copier
Oct 11, 2009 | Weaver Rifle Scopes Grand Slam Silver...
Apr 10, 2009 | 2005 Dodge Magnum
May 20, 2007 | Minolta QMS 2200DL Laser Printer
65 people viewed this question
