Question about Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range
Where to find regulator valve??
I am having touble with the oven. the element glows bright red so i think it's working but there doesn't seem to be any propane coming through the lines. another expert said it's probably the regulator valve not switched on...where do i find this??
thanks
braggsisland
  • tina oram May 22, 2008
    Thanks to you company for all your helpful advice. It is greatly appreciated.
    Braggsisland
  • 5,911 Answers
Just because an igniter is glowing does not necessarily mean it is good. Click on the following link for some helpful advice on how to determine if the igniter is working properly:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Now...if you still suspect a gas regulator problem, it is usually located in the back of the range near the bottom. Following the gas lines form the oven manifolds will help you. You may have to remove the back panel or remove the bottom drawer to access. CAUTION: Use care if you have to move the range that you don't stress the gas lines. This can cause gas leaks. On the side of the regulator or gas safety valve is a gas safety switch. Sometimes this switch gets turned off when moving the range. There should be printed instructions on the valve showing what position the switch should be in.
I hope this helps you. If you need further assistance, please let me know.
Posted on May 22, 2008
Hg2415uc siemens oven not heating
The ignitor, or glow coil, has to draw something like 3.2 amps for the safety gas valve to open to let gas in. With that said, just because the ignitor is glowing, doesn't mean that its working properly. I've had to change one safety valve in a total of 13 years of doing this, so I'm thinking the ignitor on your machine is bad.
May 28, 2012 | Siemens HG2415UC Stainless Steel Gas...
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 13, 2011 | Jenn-Air Ovens
My electrolux EOB5610 wont heat up....the fan works and the grill works but will not reach any sort of temp !!!!
Jun 02, 2011 | Electrolux EOB5610 Ultrafan Electric...
The stove burners work but oven doesnt i did test and display says good but it says cool on display
First, check to see if the ignitor glows after turning the oven on. Give the ignitor about a minute or so and you should see a bright yellow glow from the ignitor. If not, you have either a faulty Oven Control or a burnt out ignitor.
If you do see a bright yellow glow (dull orange indicates a burnt out ignitor), you could have a problem with the safety valve or the regulator. First check to see that the "flip switch" on your regulator is turned to the on position. This switch is usually located towards the bottom of the regulator. This switch controls the gas flow to the oven only, and should be in the down position.
If the switch on your regulator is on (some models may not have this switch), then the safety valve is quite likely the problem.
Apr 15, 2011 | Kitchen Ranges
I have a Kenmore Gas Wall Oven Model Number 911.30469894. When BAKE is selected, temperature shows 100 degrees and the oven never starts up or gets hot. BROIL works fine. Thank you, John
The oven control supplies voltage to the oven igniter/gas valve circuit. When the oven control is set to Bake, voltage is supplied to the oven igniter which should glow bright red to almost white hot. Once the igniter comes on and begins to glow it must pull enough current to cause the gas valve to open so the burner can ignite from the igniter. I added an image below with the theory of operation. Click this link:--http://media.fotki.com/1_p,swbbsqrsgstsqkkxgtqsskgwtqkq,vi/wrgtsbrktxwdfwfbgdg/1/1303472/5961857/image5576034710104836299img-or.png
----Open the broiler drawer and then set the oven control to bake and watch to see if the glow bar igniter glows or not. If it does not glow, the failure could be a broken Igniter, failed oven control board or gas valve. If the igniter is glowing red, then it can be possible that gas valve is faulty. To see how igniter looks. See the fig below:--
To order this part click the link below:--
http://www.repairclinic.com/PartDetail/Hot-Surface-Glow-Bar-Igniter/1990?modelNumber=911.30469894
Also to confirm, check to see if the igniter is getting 120 volts when it's turned on. If it gets 120 volts, then your safety gas valve is bad because it's not letting the neutral go through. Otherwise, if it's NOT getting 120 volts, your control board shorted out and you need a new control board.
But as you mentioned that control board is replaced. So igniter should get 120 volts. If valve is faulty. But if igniter is not glowing then its faulty igniter confirmed.
To see how gas valve looks, please click the link below:---
http://www.repairclinic.com/PartDetail/Gas-Safety-Valve-Assembly/251898
In most of the cases the igniter is faulty, because gas valve getting faulty is very rare. But still getting the voltages checked, will confirm. These will help. Thanks. Helpmech.
Feb 04, 2011 | Kenmore 30464 / 30465 / 30469 Gas Single...
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Miele Oven H316 When using fan forced the area behind the back plate where the fan is glows very red. If stop fan forced cooking and revert to normal conventional heating red glow does not appear. Fan...
element should glow dull red when on fan oven but not bright red. are you sure fan is operating? remember there are two fans - oven fan and casing fan and you may be listening to casing fan
Nov 17, 2008 | Kitchen Ranges
Frigidaire gas range FGF337
The ignitor should be almost a white hot color very bright . If it is orange or kinda reddish, the ignitor probably isn't getting hot enough to open the saftey valve. you could check the amp draw on ignitor , but most of the time if the ignitor isn't glowing bright almost white , that is probably the problem, besides that if and only if ignitor was good then i would look at the saftey valve. My money is on the ignitor.:)
May 19, 2008 | GE JGBP28 Gas Kitchen Range
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range Logo
161 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
