Question about Epson Stylus Photo R1800 InkJet Printer
'communication error' and won't turn off
I cannot get my computer (G5 imac running 10.4.11) to talk to my Epson 1800 printer. I keep getting the 'communication error' message from the printer utility. Please note that:
- nothing has changed in my computer set-up since I last used it without problem a few days ago
- I tested the firewire cable by plugging an external drive into it which mounted on my mac without problem
- I have rebooted mac and printer a few times with no change
- The printer seems to go through it's start-up routine without throwing up any errors but I notice that I cannot switch it off via the power switch - I have to pull the cable out of the back
I think there is something wrong with the printer but what and how do I fix it? Any advice appreciated.
  • 1 more comment
  • rabvp Jun 24, 2008
    My R1800 had been unplugged for a while after I moved. About three weeks. It'd been in this scenario before and worked fine. Anyway, when I went to turn it on again, the power light came on, the low ink light came on, and the carriage slowly moved to the left... then nothing. No flashing lights, no pump motor, and I had to unplug it to turn it off.
    Since I have unlocked the carriage, moved it to the middle, and turned it on just to see if it would return the carriage. It did, but with those two lights remaining on, and very, very slowly. Still have to unplug it.
  • Anonymous Oct 16, 2008
    Can't get R1800 working in 10.5.2
  • Anonymous Mar 27, 2014
    I accidentally plugged the USB cable into the printer the wrong way round and now I just get communication error messages. There are no flashing lights and the control panel is functioning as normal. Is it likely to be a software malfunction and should I to re-install?
  • 110 Answers
From my experience, FW and Epson printers don't always work well together.
Switch it to USB then delete and re-add the printer in the PRINTER SETUP UTILITY, and you should be okay
Posted on Aug 22, 2008
The issue is not whether firewire or USB, but I think epson puts cheap switches/sockets in. My printer was doing the same thing, I realized the Firewire socket had died... it now works perfectly that I've switched to USB.
Posted on Oct 07, 2008
Epson Stylus Pro 4800 printing problem
Communication error typically means that your printer and computer aren't talking. Assuming you're using a USB cable, try a replacement cable, in another socket on the computer.
Dec 21, 2015 | Epson Stylus Pro 4800 InkJet Printer
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
I will type the wifi password it to the computer and it won't join. it keeps saying error joining the airport
The causes of this can be varied. Try adding a $ infront of the wifi password and see what happens.e.g. $hamster123
Aug 08, 2011 | Apple iMac G5 Desktop
Artisan 800 fax keeps getting communication error 0402
When I went to my epson account noticed that I had a toll free number after hours to call and talked to them and turns out one of the fax settings ECM should of been Off and everything works fine.
Oct 07, 2009 | Epson Stylus Multifunction Printer/...
"Communication error"
How do you connect the printer to your imac? what type of cable are you using? if its a USB connection, then try going to system profiler and under hardware click on USB and on USB device tree you should have highspeed USB 2.0 and when you highlight that, it should give info for manufacturer as EPSON if thats the brand of the printer you are currently using. update me on this so that we can check if its really communicating with your imac-- thanks!
Jul 07, 2008 | Epson Stylus CX4200 All-In-One InkJet...
My printer (Epson Stylus DX4200) does not work.
hi check here for your drivers or epson main web site may have them also .
Nov 20, 2007 | Apple iMac G5 Desktop
Epson Stylus Photo R1800 InkJet Printer Logo
569 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
