Question about LG Studioworks 563N 15" CRT Monitor
My LG CRT monitor does not display any thing when powered on
Actually it only shows amber colour light when power is on,no display at all.
help me out.
  • 2 more comments
  • svtambare Jun 10, 2008
    My monitor is showing only one horizontal beam, not complete display... whats the reason?
  • suresh_a Jun 29, 2008
    I have the following model
    LG Studio works 500G Model No CB553H-NA
    When I switch my PC on, I could see amber light glowing for some time and gets switched off automatically. The monitor is black and does not display anything
    However, i have checked connecting my monitor to my Laptop and it works fine.
    The problem is only with connecting from my PC. Can you provide a possible solution
  • srinivas_elr Jul 12, 2008
    When I switch my PC on, I could see amber light glowing in my monitor. before this problem in the monitor the red colour is missed. so i removed the back pannel of the monitor and checked for fail components and dry solder. but nothing was appear. when ever the yoke board pushing the problem is solved temperarly. so i removed that and checked for loose contacts and resolder imp connections with out fail. after that the monitor is changed to amber light glow. so please kindly send the solution to my id psdsrinivas@yahoo.com.
  • Anonymous Jan 28, 2009
    my monitor went off and it isplays the amber light.i tried to open the cpu to check the vga and in the process lost all my documents.wat went wrong.eugene
My LG CRT monitor does not display any thing when its powerd on .
Posted on Sep 29, 2008
Check the monitor on different if possible. If the problem continues on different computer then the display card on the motherboard has to be replaced.
Posted on Oct 17, 2008
My monitor has no display even I powered on the switch, then the light from switch is blinking..
Posted on Jun 04, 2008
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from...
it was a blown or bulging electrolytic capacitor at the PSU with high ESR. just replace bad caps to a low ESR a panasonic brand much better 105c rating.make sure the same voltage and capacitance rating to avoid other possible problem may occur good luck.
Jun 23, 2012 | LG Flatron Computers & Internet
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
Display problem in my LG 15'' monitors
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Nov 22, 2008 | LG Studioworks 563N 15" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
Not turning on
mine is doing the same after it rained on it........
Jun 16, 2008 | Apple M6496 17" CRT Monitor
Crt screen power not appear
1)check the power supply
2)write in a desktop<properties<settings
3)setting<control pannel<display,appearance
Oct 13, 2007 | LG Studioworks 563N 15" CRT Monitor
Monitor not activating
Sounds like will need component-level electronic troubleshooting, probably in the power supply section.
Jan 02, 2007 | HP Pavilion MX70 17" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
887 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
