Question about HP Compaq Presario R4000 Notebook
Presario R4000 does not detect 2GB of memory
My laptop is a Compaq Presario R4000 (PN495AV) and will support up to 2 GB maximum. I am trying to upgrade the memory from 2 x 256MB to 2 x 1GB. I have 333MHz PC2700 DDR chips.
With both chips installed, the laptop will not even boot to POST. Nothing is on the screen.
The laptop boots fine with 1GB and Windows XP Professional load fine.
With 1GB and 1 x 256MB installed, POST shows 1280MB but Windows XP will not load. I know Windows XP (32-bit) will recognize up to 3GB (4GB addressable) so I suspect a hardware problem.
Any ideas?
Many thanks,
Tom
  • PhotoTom May 22, 2008
    Hi Theknack,
    Each chip works fine in either slot alone. I checked the HP site and they have a newer BIOS so I will try it next. I also heard back from the memory retailer who has another customer with the same problem and he said a BIOS upgrade fixed it. I will let you know the result. Many thanks.
  • PhotoTom May 23, 2008
    Hi Theknack, I upgraded the BIOS and the laptop detects 2GB. Windows loads fine. Many thanks.
    Scholar:
  • 144 Answers
Hi PhotoTom,
I check you laptop specification and it really do support uptp 2 GB. So here I'm not sure your 1GB are both of them DDR 333Mhz ?? .If so what I really want you to test here is
1. 1 GB in one slot and turn it on (as you say you can boot wih it) after that move that 1 GB to the other slot and see.
2. try the same with the other 1GB and see that both work fine on both slot or not.
Incase both work fine on both slot then maybe problem with hardware what I want you to do after that is try to check your BIOS version and check on the website that they do have new BIOS version or not ?? Coz this can help incase problem are from BIOS.
Goodluck,takecare.
Posted on May 21, 2008
  • Technocom
    Technocom May 24, 2008
    Good to hear about it.
    takecare.
Will a compaq Presario R3000 take one 2 G memory stick? I am trying to upgrade the memory on my partner's laptop. Can 1 stick of memory, 2GB, be used instead of 2 1 Gigs?
Hi Bronzen...
HP website for you laptop...
Please take time to rate me
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=384511&prodTypeId=321957&prodSeriesId=384511&objectID=c00208189
According to the HP website: 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB
Sep 15, 2011 | Compaq Presario R3000 Notebook
HP Compaq Presario R4000 (PN495AV) PC Notebook How
Yes, go to Start>Control panel>Power Options. There also should be a screen brightness key on your key board, that looks like a sun shining, with arrows pointing up & down. To use that key, hit the FN key, right next to the Ctrl key. Push & hold the FN key, while pushing the up arrow. That should increase the brightness of your display. Good luck.
Jul 06, 2011 | HP Compaq Presario R4000 Notebook
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
Thanks to Microsoft Knowledge Base for help with my answer:
First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
Jul 07, 2009 | HP Compaq Presario V3000T Notebook
COMPAQ LAPTOP MAMORY EXTEND
This laptop has 2 slots
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot.
So maximum memory supported is 1GB.
If you install more memory there is a high probability it will not be recognised.
You can get more information and order memory from the link below:
http://www.crucial.com/store/listparts.aspx?model=Presario%20M2000%20Series
Jun 08, 2009 | Compaq Presario M2000 Notebook
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
Adding an additional memory module to laptop...wont start!!!
The problem is that your laptop only supports 2 GB of RAM. If there is not a newer bios allowing more then 2 GB is the max you can go. Since you put the 2 GB in one slot then the other slot will be useless. It wouldn't matter how much you put in the 2nd slot because the bios already says you have 2 GB on board and will not accept anymore. Sorry.
Apr 08, 2009 | HP Compaq Presario C500t Notebook
No Power vailable to Compaq R4000 PN495AV
well..this will require a new motherboard(around 200.00) and two hours of tech time(around 200.00) so compaq was high, but not that high..
check in the repair listings at fixya for more on this option
May 23, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
