Question about Samsung SCX-4100 All-In-One Laser Printer
Failure to print
The printer keep signalling " Open heat error"
  • Anonymous Aug 04, 2008
    fasdfasfsafasf
  • 3 Answers
Hy i had the same error message the error comes from the fuser unit , the halogen lamp is not heating , on the top of the fuser unit is a Thermostat in series with the halogen lamp wich u have to replace. Its not that easy if you dont have experince but it will solve the heat error. I hope this helped
Posted on Dec 18, 2008
DEAR,COSTOMER SERVICE
printers no relation computer.please give me a softer which is download printer model-samsung scx-4100.
Posted on Jun 07, 2008
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
Oct 30, 2013 | Office Equipment & Supplies
Hi this is hari, am using samsung scx4300 printer and i installed drivers.but am getting a error in display like "Open heat error", Please could some one help me for smme. Thanks,
Dear
The open heat error due to the temp. of fusser has not attained within predefined time due to either failure of heater lamp(rare),failure of thermostat(frequent),failure of fusser assembly(melt).
In first two case the parts can replaced(may be reset thermostat by knocking on hard surface) but incase of fuser melts then both fusser assy. and smps to be replaced confirm whether the printer power from DG set.
Thanks.
Jan 16, 2011 | Samsung SCX-4300 Monochrome Laser...
Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
Feb 09, 2010 | Canon BubleJet i965 InkJet Printer
Printer will not print. keeps saying
first you pl. check the dimm/sdram module is seated properly in its place otherwise insert new one
Feb 05, 2010 | HP LaserJet P3005n Printer
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
I have error 37,002.47
Hi, the error code you are getting refers to not enough current to power up the printer. I would suggest if you have it on a surge protecter, backups,etc . Disconnect the printer and plug it directly into the wall outlet.
Nov 30, 2007 | Xerox Phaser 8400DP Thermal Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
330 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
