Avery 08371 Business Card Stock, Kodak 5300
Unable to print business cards with Avery 08371 Ink Jet cards with my Kodak 5300 printer. Any thing I can do? This is costing me money.
Rick
  • afischer49 Sep 27, 2008
    I too cannot print avery business cards from their card stock. It says Iv'e loaded the paper wrong and to load it print side down. Can it see the instructions printed on the page and thinks we have it wrong side up in the paper cartrage?
SOURCE: Problem printing business cards
in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
Posted on Mar 13, 2008
  • 848 Answers
SOURCE: On printing business cards with
what is the make of your printer ?
Posted on Aug 26, 2008
  • 461 Answers
SOURCE: i cant print business cards on my hp c5280
Verify no pieces of the card paper are missing and try printing on plain paper to make sure. Then try new card paper and make sure none of the perforations are separated.
Posted on Dec 29, 2008
yooperbud
  • 8637 Answers
SOURCE: Printer problem
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
micromaster
  • 3614 Answers
SOURCE: HP F4280 All in one
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Posted on Sep 17, 2009
How do I print cardstock with Samsung ML-2510?
Hi
I found a manual for your printer here:
http://downloadcenter.samsung.com/content/MM/200605/20060510151657234/um_ml-2570_manual_eng_060328.pdf
and under print media, it suggests limits of 60 to 163 g/m2 for the 2 trays. If you get some 160 g/sm2 card which is quite readily available, I think you will find it much lighter than the Avery business cards card, which from memory come in around the 200 - 220 g/sm2 level.
Even Avery quote this card as "heavyweight card stock", and although the say will print on all laser printers, it's my experience that they do not. Only on a laser with a flat paper path.
Cheers
Mar 02, 2015 | Avery 5376 Perforated Business Card
My HP Deskjt F4280 will not print Avery injet 08371 business cards. I tryed the other number on the cards, 5371. Neither of them will line up proper. If I print on a blank paper it is printed correct. ...
you realy cannot print with that paper the ink cannot penetrate through, i have an experience here before and tried it on epson it print perfectly
Aug 07, 2011 | Office Equipment & Supplies
HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Jan 05, 2010 | Office Equipment & Supplies
Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
Jul 30, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Jammed card stock
This machine has auto paper type sensor- may be at fault
May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
Mar 18, 2009 | Lexmark X6570 InkJet Printer
I am printing business cards and I am using thick paper but colors come out dull looking but if I change the paper to PLAIN then the colors come out just perfect, full, vivid and rich but I am afraid that...
Its most likely the paper you are printing on. It sounds like this is an ink printer. The way ink works is that it is absorbed into the paper you are printing on. Some paper pulls the ink too far into the paper causing it to look dull and faded. You need to make sure you are printing on paper that is designed for inkjet printers. There are a lot of companies that make special paper designed for printing your own business cards. I prefer Avery products since they have a guarantee.
Check this link out for some options on InkJet business card options.
http://www.avery.com/avery/en_us/Products/Cards/Business-Cards/_/Ns=Rank%7C1%7C%7CProduct%20Number%7C1
I hope this is solves your issue....Violet
Jan 23, 2009 | Office Equipment & Supplies
Printer problem
Dec 30, 2008 | Office Equipment & Supplies
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
604 people viewed this question
jasbo
jasbo
