Question about HP LaserJet 3030 All-In-One Printer
Start-up Noise On Starting, after completing initialization, it makes rattling noise for ever
  • 86 Answers
You will need to open the printer and check for jamed paper or something if there is nothing like this then call the service....
Posted on May 26, 2008
I have a 12.5 hp Briggs and stratton lawn mower engine that will not start. It has fresh gas and a new spark plug. every time i try to crank it it makes a rattling noise
The rattling noise may or may not be related to the motor not starting, but I'd definitely figure out what's causing the noise first. Could be anything from busted ratchet pieces in the recoil mechanism to a piece of debris dragging across the flywheel fan blades to a loose coil to a busted connecting rod down to a broken governor, bad main bearing or loose blade. Since I can't hear the noise, I'd recommend first checking the one of those things that would definitely make a rattling noise and would definitely keep the motor from starting: Remove the spark plug and shine a penlight into the cylinder, noting the position of the piston. Pull the starter rope just enough to make the engine turn over partway. Repeat a few times. If the piston doesn't move, busted rod. That'd be both the source of the noise and why it won't start. If the piston does move, I'd work by process of elimination until I found and addressed the source of the noise. That done, make sure you have a good spark when you crank it. That done, the problem is almost certainly a dirty carb. If your carb has what appears to be a 1/2" nut holding the bowl on, either shut off the fuel valve (if your motor has one) or clamp the fuel line to the carb and remove the 1/2" nut from the bottom of the carb bowl. The "nut" is actually the main jet. Clean it and the bowl with carb cleaner, making sure the tiny holes in the nut/jet are squeaky clean. Reassemble, remove the clamp and try again. If still no go (or it's the older-style carb with screws holding the bowl on) you'll have to pull the carb and do a complete disassembly and cleaning. Dang this was a long-winded answer but I didn't have much to go on. Hope it helps.
Apr 05, 2016 | Murray Garden
Solenoid rattle on start up. Goes away immediately on start. V 6 motor
peugeot 407 v6 3.0 very short-time rattling(grinding) noise at ...
? 0:13
https://www.youtube.com/watch?v=ZRJzci7qvNA
Feb 27, 2012 - Uploaded by reza679
peugeot 407 v6 3.0 very short-time rattling(grinding) noise at cold-start, source ... but a friend told me it can be anything else as well (like those solenoids)! ... C6 makes when starting cold - is that a VVT or a valve lifter noise?.
407 [Archive] - Peugeot Forums
www.peugeotforums.com > Peugeot Forums > Peugeot Models
Mar 22, 2011 - Key replacement · Wishbones for 407 · ESP/ASR Faulty · RT4 VIN coding · 407 1.6 2004, Crankshaft pulley.. size, part number.. 407 driver door lock replacement ... Peugeotforums.com Suggestions and Help [Archive ...
Mar 24, 2011
General Discussion [Archive] - Page 4
Mar 21, 2011
More results from www.peugeotforums.com
Jan 26, 2016 | 2006 Peugeot 407 1.6
Starter makes loud noise when starting engine
What kind of noise? clunk, grinding? rattle? Does the bike start and run okay.
Jun 10, 2014 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Mark II Grande cylinder head noise
Sounds like a bad rod bearing, no cure except a rebuild. I assume you do know the difference between spark knock and bearing knock.
Mar 21, 2017 | Cars & Trucks
Hi I have a engine rattle in my 2000 model 2.4l on first start up in the morning disappears after a minute or so.Could it be a hydraulic lifter?
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make rattling noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help link mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-noisesnoisy-cargrinding.html
These will help.
Thanks.
Dec 17, 2012 | Cars & Trucks
What is the rattling noise i hear when i accelarate in my cadillac deville. 1995
Check your oil. If oil is too low, it makes a rattling noise in acceleration. Also, be careful that it isn't your timing chain. The timing chain, once it's starting to fail, will make that noise as well.
Mar 25, 2012 | 1995 Cadillac DeVille
Switch on compressor clicks on loudly and compressor makes a rattling noise when it runs.
if your sure it is the compressor relay that is making the noise then i would suggest replacing it fast... it may be getting weak and will leave the milk spoiling soon... another possibility is that the compressor it self is starting to get harder to crank and or the compressor itself is getting ready to go out...you may be hearing a rattle because sometimes it is not starting and the rattle is the compressor vibrating because of a weak start relay... hopeful thats the case if it constantly is rattling then i would say the compressor valves are starting to fail adn won't be long before you are shopping for a new unit or a appliance repair man ...good luck to you...lets hope you caught it early enough ....
Feb 11, 2011 | Maytag MZD2766G Side by Side Refrigerator
I have a 2001 Ford ranger supercab that makes rattling noises. It has a 4.0L SOHC. It makes a very fast and loud metallic rattle wich softens anfter about a second or so when I first start it for the day....
4.0l's are notorious for valve rattle on cold start-up. There is really nothing you can do to make it go away short of completely replacing the valve train in the top end, and that isn't a permanent fix. It's is an top end oiling issue from the factory. Just don't race your engine on cold start-up until the rattle stops.
The rattle in the transmission sounds to me to be more of a loose dust shield/heat shield around the transmission or exhaust than a mechanical issue.
Oct 20, 2009 | 2000 Ford Ranger SuperCab
Starts hard and rattle noise under car
the rttling noise is most likeky the heat shield over the catalytic convertor on the exsaust.
Apr 19, 2009 | 1999 Oldsmobile Intrigue
2004 expedition
This may be due to old oil. I'd first try changing the oil. The viscosity of old oil may be to thin causing serious run off in the top end. All of the lubrication may be off of the valve assembly causing it to chatter and make these noises until the motor can re-lubricate the valve train.
Also, it may be due to low oil, to heavy of a wieght of oil (such as 15w40 or 20x50). I believe with most of the 04's the recommended oil weight is 5w30.
Try an oil change and see if the noise goes away. If it doesn't I'd do a quick visual inspection under the hood for rattling parts while the engine is running. It could just be a loose housing or something causing the noise. Hope this helps bud!
Sep 11, 2008 | 2004 Ford Expedition
HP LaserJet 3030 All-In-One Printer Logo
117 people viewed this question
Ben Johnson
