Question about HP Pavilion dv9000z Notebook
Vhs to dvd
I can copy it to the hard drive, but it won't copy to my dvd burner
I have dvd+R and dvd +RW, but I think I seen it on my laptop
somewhere that it requires dvd-R- ....
does it make a difference ? I ended up buying a Dazzle Recorder
that copies from the VCR , and uses the laptop for a monitor,
but it was made for Windows XP
so I had to download a patch from Pinnacle to run it.
I'm ready to bring the recorder back and try to get an all
in one vcr/ dvd recorder........I only need something to
copy my old vcr tapes of my kids and some old vodeos of when I
was small...........any help would be great !!
thanks
deb
  • dsingh3796 May 22, 2008
    Unfortunetly for me, I only have the old vcr to use to play the vhs
    tapes. I can copy the video to an avi file, but when I go to copy it to a dvd, it's windows vista that gives me the problem :-(
  • 1,031 Answers
Get a TV card (PCI, USB or PCMCIA); plug an AV cable from the back of the VCR to the TV card, then use the software supplied with the TV card to write the input to an AVI file... The playback has to be 1 to 1,
write the AVI to a DVD using any DVD, or VCD creation software... If you want multiple copies copy the DVD, don't re-write it from the source material (it is quicker)... And then delete the source AVI.
If you don't have a TV card but have a digital camcorder see if it supports AV-IN. When you do this I go from my VCR to the camera then to a firewire port on the PC. The camera acts as a bridge. you can burn it with Nero 5.5xx Get very good results this way.
Posted on May 22, 2008
My laptop's not wanting to burn DVD-RW any more. I had to replace the hard drive and ever since then it wont burn an RW disc. It will erase them, and play them. Even the old RW disks from before I...
DRIVERS
Go to the website for the DVD Maker and download the latest drivers.
No reason this won't correct the problem.
Don't go to Sony unless they made the DVD burner.
Aug 14, 2011 | Sony VAIO VGN-NW310F/T Notebook
I'm using a Dell Inspiron 1300 Laptop with an NEC DVD+-RW ND-6650A CD/DVD reader/writer. Also using Showbiz DVD2 to burn backups of VHS tapes I can create single layer DVDs fine. However, when I try to...
how long is the whole process of burning the dual layer dvd's
your computers hard drive might be getting to hot
try blowing out all of the dust from your laptop computers keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of unforseen problems with a computer and its parts
also you might buy a laptop usb 3 fan cooler pad just to keep things cool/er
you might check the leads ((motherboard to hard drive)) they might be bad/faulty
hope this helps
Mar 07, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
Burn dvd from vhs
i'm assuming you have a vcr to play your vhs tapes, just plug your audio/video cord from your vcr(out), plug into the audio/video vc10(in), start playing vcr and press rec botton whenever you want to start to record. make sure you can only use dvd+r. choose the quality for the length of time, at the end press 'function' to finalize the disc, then you are done.
Sep 06, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Dvd burner question
First off is the drive a read only drive or a Read/write drive? If you look at the front drawer check to see if there is a big RW(read/writable) on the front of the drawer. If it doesn't have the RW then you won't be able to burn discs. If it says RW then you will be able use it to copy DVDs. You accomplish this by using software to copy the disc you're interested in to your hard drive and then using the copy on the hard disc to copy back to a blank recordable DVD placed in to tray.
Jul 23, 2008 | Computers & Internet
DVD Burner will not burn
Read the front of your drive to see if you have a DVD-R or DVD-RW drive. A DVD-R will copy a DVD to your hard drive, but will not burn it. If you do have a DVD-RW drive, try a different brand of disc or a DVD-R disc, some drive are just temperamental.
Jun 13, 2008 | Toshiba Satellite A105 Notebook
Won"t see blank disc
given my experience with memorex blanks, i think that you should just switch to another brand....memorex made great tape....the cd blanks are another story. I recommend, if you can find them, FUJI blanks that are made in Japan; they have a reputation as some of the best.
May 30, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
Burning problem
When you open Nero select copy dvd. Select the dvd-rom as the read drive. Put the dvd to be copied in there. Select the dvd-rw as the write drive and place a blank dvd r or dvd rw in it the select copy.
Mar 01, 2008 | LG GSA-H10N DVD±RW Dual Layer Burner
Problems dubbing from hard drive to DVD RW disk
Switch CD R or DVD R
RW disks are not suitable for this work.
Dec 17, 2007 | Computers & Internet
LG vs Lite On
both are just the same features just to write file from your hard drive. Maybe your point is you want the video from your VHS tapes will transfer to your hard drive. The only way to copy the video from your VHS is you need an external VHS player at the same time it will record the running video to a soft copy.
Please check this maybe this will be helpful http://www.allformp3.com/dvd-copy-software/convert-vhs-to-dvd.htm
Please rate me solve if you like my solution.
Best regards,
Philip
Oct 31, 2007 | Lite On (ldw811s) DVD±RW Burner
Acer TravelMate 530 - CD Drive Upgradeable?
As far as i am aware cd drives in acer laptops are not hot swapable, in other words non replaceable.
May 18, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
HP Pavilion dv9000z Notebook Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
