Question about Sony Cyber-shot DSC-S700 Digital Camera
No power my camera does not turn on power , the batteries are replaced with all new
  • 57 Answers
Has it always been that way? You may want to use the same type of batteries; exp: alkaline, rechargble?, that came with the camera. If I'm not mistaken this camera has a battery type setting that has to match the type of batteries you are using.
Posted on May 21, 2008
Exchausted battery in polariod camera
Are you sure that NEW batteries are good? sometimes bad, exhausted batteries go for sale as scam
Jan 26, 2014 | Nikon COOLPIX L12 Digital Camera
The camera will not turn on even though batteries are new.
Hi Kris - If the camera worked before changing the batteries, but now it doesn't; check the batteries for proper insertion. If just one battery was installed incorrectly, the camera will not power up. Also, check the charge of the batteries. If even a single dead battery was included in the mix of new batteries, the camera will not power up either.
If all these conditions check out ok, the problem may be related to defective hardware (power switch, lens, etc.). When the camera is powered on, it goes through a quick self test. If any of these self tests fail, the camera shuts off immediately. This will often require that the camera be evaluated professionally. Hopefully, you'll find the problem is battery related.
Nov 21, 2011 | Canon PowerShot S51S Digital Camera
My camedia Olympus c3000 won't turn on with brand new charged batteries.
TROUBLESHOOTING
OPERATING PROBLEMS
The camera does not work.
1 The power is OFF.
[ Set the Mode dial to turn on the power. (P. 36)
2 The batteries are loaded incorrectly.
[ Reload the batteries correctly. (P. 28)
3 The batteries are exhausted.
[Replace the batteries with new ones. (P. 28)
4 The batteries are temporarily unable to function.
[Keep the batteries warm while using the camera.
5 Power has shut off to conserve battery consumption.
[Operate the shutter button or the zoom lever.
6 It is connected to a personal computer.
[The camera will not operate while it is connected to a personal
computer.
Jul 14, 2010 | Cameras
My Fuji FinePix A900 camera's batteries are low. I have tried to replace them with new batteries, but the camera will not turn on. It will only turn on with the old batteries in it. What's up with this?...
if you are using rechargable batteries make sure they are fully charged, try more powerful batteries.
clean each end of batteries and the contacts inside the camera for better electrical contact.
Mar 28, 2010 | Fuji FinePix A900 Digital Camera
New batteries but the camera will not turn on.
New or old. They could still be faulty. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EASYSHARE M1063 Digital Camera
Whenever I turn camera on it immediately turns off.Battery new and fully charged.
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 18, 2010 | Kodak EasyShare M873 Digital Camera
I have Kodak EasyShere V1223 It won,t Turn on, Go
Here are the steps for V1223 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare One Digital Camera
Our camera just stopped powering on. We have
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Dec 30, 2009 | Kodak EasyShare C743 Digital Camera
IT HAS BRAND NEW AA BATTERIES IT WILL TURN ON BUT THEN TURN OFF
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though brand new and right out of the package, they may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Modern rechargeable batteries (I'm not talking about old NiCad's, those are awful) can hold over five times the amount of power of an old fashioned alkaline battery. Also keep in mind that rechargeable batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Oct 26, 2009 | Cameras
I can't get my easy share camera to come on
turn on when I push the power button...it will power on when I use the power cord...but not with the battery by itself...I have replaced the battery with a new one, and it still doesn't power on...please help...
Aug 16, 2009 | Kodak EasyShare One Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
48 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
