Question about Toshiba Satellite A135-S4527 Notebook
Starting Up When I turn on my computer, I get a black screen with white writing that says that my computer was shut down improperly due to a power failure. It says to start it in safe mode (there are 3 different safe mode options) or to try the last known configuration that works. When I try any of these options, it tries to start up, but always comes back to this same screen.
    Scholar:
  • 110 Answers
If your machine can't start in safe mode, you will need to reinstall Windows. When you get to the point where it asks you where you want to install, it should offer you the choice of "repair installation" - if you opt for this, you won't lose any of your data or settings.
Posted on May 26, 2008
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
Having trouble hooking up a Microsoft windows XP media Center edition 2005 computer it loads with a black screen with white writing and says things about safety modes
ok that means it was shut down improperly recently run in safe mode, then restart it when you have a moment
that should clear that safe mode issue
May 20, 2012 | HP Computers & Internet
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
LG L222WS half bottom screen white
There is a problem with the capacitors in your monitor. This is a normal problem these days with flat screen monitors, I am trying to find out why it is always like tha. This will normally be caused by improper shut down or power fluctuations in your monitor. Capacitrs in your monitor are responsible for holding down the power from the supply, fr the proper display on your monitor. If a capacitor is damaged, or buldged, it no longer holds power long enough for your display, and that is why your screen goes black after a few seconds. This can be solved by opening up your monitor, using a sharp and flat object, opening it starting from the bottom working your way up until the cover is completely out. You will notice finger-like clips that are holding the two covers together. Once you are done, check on the circut board where you connect the power cable.... that is where you are going to find the damaged capacitor(s). You can identify them by noting their bulged head or if there is any liquid coming out of it. Before you replace the, take note of the polarity (+) and (-) so that whenever you replace with the new one it is in the same direction. This will fix up your problem. Note: make sure you let a Computer Technician to do this for you, unless you can do it yourself without damaging the monitor. Thank you
Dec 13, 2011 | LG L222WS-BN Wide-format 22 22 inch LCD...
Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard and cross your fingers.
Good Luck!
Mar 31, 2011 | Acer Computers & Internet
Dell Inspiron 1420 blackened screen when turning on problem
Go back into Safe Mode, and try to run a system restore to a date where this issue did not exist.
Jan 10, 2010 | Dell Inspiron 1420 Notebook
Turn my acer on and the screen is black with white writing, then it looks like it is going to open windows but doesn't and goes back to the black screen with white writing, has prompts to starts windows...
Found this on the Web. If you find this helpful, pls rate me.
Shut down and again start your computer....press F8 while it is starting it will take it to safe mode
Then, please perform the steps below.To use the System Restore Wizard, make sure you're logged on as an administrator, and then follow these steps:
1.Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3. On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, and then click Next.
This should solve your issue but this will disable your latest downloads.
Good Luck...
Jan 08, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Dell Inspiron 1501 black screen
Post the error codes that are given and I'll be able to tell you what's going on exactly.
Jun 19, 2008 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
