Canon LaserClass 9000 Fax Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to program speed dial for my lc9000 fax - Canon LaserClass 9000 Fax
thane ntozini
Level 2:
New Friend:
  • Expert 121 Answers
  • Posted on Sep 23, 2010
thane ntozini
Expert
Level 2:
New Friend:
Answers
121
Questions
Helped
17597
Points
374
Download the manual, or check if it wasnt shipped with. sometimes its on a CD
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
How do I change the time on a LC9000
Open the speed dial button panel/frame
press DATA REGISTRATION
press SET (to choose data reg.)
press SET (to choose User Settings)
press SET (to choose Date & Time)
Enter date & time (in 24h format)
press SET
press STOP.
By the way, here's the link to the owner's manual in PDF - rather hard to find, as Canon does not post manuals on their support site (shame!).
http://www.zeronine.ca/downloads/Downloads/Pengrowth/Printers/CLC9000.pdf
Good luck :)
1helpful
How to programm my fax number
Here is a link to your Canon LaserClass 9000 users guide, unfortunately it was scanned 90 degrees off.
http://www.actcopiers.com/Manuals/LC9000.pdf
Setting up group dial will allow you to send to multiple locations with only one scan of document(s). Programming fax number should be located on page 3-5.
1helpful
2answers
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
3helpful
Trying to change a fax number in memory
To change info:
"user tools" (ok)
"fax features" (ok)
"general settings /Adjust" (ok)
"program fax info" (ok)
...then set name, number, etc.
"user tools" to exit
To print speed dials:
"user tools " (ok)
"fax features" (ok)
"reports / lists" (ok)
"dial list" (ok)
"Quick dial list" or "speed dial list", etc (ok)
I hope I'm your Hero now :)
Please rate me.
I work for the county and I have to dial a code # first
18001234567,1234567890,1234567890
program your speed dial with 'symbols(button)' between the groups of numbers,
the 'symbols' adds a 2second delay between the dialed characters at that point.
except for the first 'symbol' the first 'symbol' pauses till the other end answers the phone and handshaking has taken place.
If the numbers are not always the same, program two speed dials, one for the 1800, one for the password.
and when sending
speeddial1 number speeddial2
Lexmark x4270
HOLD DOWN THE SPED DIAL NUMBER WHEN IT BEEP THEN ENTER THE NUMBER WITH AREA CODE YOU WANT TO DIAL, WHEN FINISHED HIT SPEED DIAL AGAIN.
old marine
old marine
ZJ Limited
ZJ Limited
