Flash drive problem
Flash drive properties shows zero bytes in both capacity and used area, yet disk space is full blue colour. when i try to format it it says no disk in the drive. Disk management utility shows no partition, nothing dead brown.Power on LED is OK. Is my falsh drive beyond rescue. Should i throw it away?
    Master:
  • 441 Answers
Try this first:
Right click my computer, then go to manage, then go to disk management and look for the removable disk (your flash disk) then right click it and try to delete and create partition. then format.
Posted on May 21, 2008
My pen dive doesn't show it memory . when i connect my 4gb pendive onto my pc then pc show me a removable disk connected but when i try to see properties then pc shows me that used space is o bytes and...
The problem you are talking about is most probably of the virus infection. Try to format your pen drive in your system and you can restore back your pen drive.
Dec 22, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
My computer detects 4 Gb pendrive (S/N 5282015959 & model TS4GJFV30 but does not open.In properties shows zero bytes but device full
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
3.b) Format pendrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 30, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
On opening a pen drive it is showing 'please insert a disk into removable disk (h:)' and opening its properties it is showing used space 0 bytes free space 0 bytes
Hello there yogeshpat876.
Here's your geek-steer ...
Is this a new drive? If so, it probably just needs to be formatted [and optionally assigned to whatever free drive (letter) you desire]:
Start > Run... > tpye "diskmgmt.msc" (without quotes), then OK
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Transcend (589307) Media
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
May 31, 2009 | Transcend (589307) Media
How to format raw sandisk 250 hard drive with window xp.i couldnot use this mp3 player after i used this device to transfer files from one computer to the other.after transferring the file,i deleted the...
Alright, plug the player in with your USB cable.
Open "My Computer" and find in on the list of drives and CD-Roms. It will be called something like "Audio Device" or "Removable Storage Device". Make sure you find the correctly icon for the player.
Right click the player then select the format option. You'll probably want to use a FAT32 format as it is the usual format for MP3 players and flash drives of the like. This will totally erase any files on the player, so be forewarned before you complete this.
Raw file system is basically the media in it's standard state. All the information is recorded as zero's and this is how your computer is seeing it. It is either reporting incorrectly due to bad file system error, or simple was formatted incorrectly.
Give that a try, let me know what happens. :) Hope it helps.
Sep 21, 2008 | Audio Players & Recorders
USB Flash Drive
- Click Start / Run / diskmgmt.msc {OK}
- Right-click the memory card, then create a partition & format it.
Jul 03, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Computers & Internet Logo
318 people viewed this question
David Payne
David Payne
