Question about Gateway FPD2275W LCD Monitor
Monitor is busted!
Mine is a 15" Samtel digital monitor (CRT). when i switch on the unit it makes a high frequency sound and all the front panel leds (power on + menu leds) start blinking, without CPU connected of course. But with CPU connected to it, the power on led turns orange and all the green menu leds (8 in total) start blinking. Any solution?
  • John Muana
    John Muana Jun 01, 2008
    the IC driving the H-out transistor was damaged. Unfortunately i coulnd find the spare so i bought a new LCD. Thanks guys for trying.
  • Gateway Master
  • 13,433 Answers
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
Posted on May 21, 2008
  • Ekse May 21, 2008
    Click here
    There you can see how cheap these things are these days.
    and here are more!
    Click here
  • Ekse Jun 01, 2008
    This thread has gone 7 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
    If the issue is not resolved, please post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
    Thank you.
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Im useuing a lg crt 15 inc monitor, few days ago im connecting my pc with samsung lcd 22 inc monitor, but the problem is when im re connecting that crt monitor its only show out of frequency.
the resolution might be too high for the CRT monitor, try to lower the resolution if your going to connect the CRT monitor..., the 22 inc monitor obviously have much higher resolution that the 15" crt monitor. i think the max for that is 1024x800.. hope this helps :)
May 10, 2011 | Computers & Internet
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
Tic tic tic sound
Check for other problems. You might need to buy another FET as well. But this time don't put the FET back in until you make sure nothing can blow it.
May 15, 2009 | LG L1915S 19" LCD Monitor
High frequency sound out of monitor
tell OS and monitor model...?
set this configration in win xp os...
1024by768 pix
and go to display properties=>advanced=>monitor=>change the frequncy....
some CRT monitors not support..
Apr 13, 2009 | Computers & Internet
Samsung 15' sync master monitor
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it...
Dec 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Not set h size in dos mode
change the monitor frequency 60 Hz.
Jun 04, 2008 | LG Studioworks 563N 15" CRT Monitor
Samsung 591s monitor
It isn't getting a steady, usable source of power, you can try to diagnose this your self but it will be a power issue INSIDE the monitor within the circuit board
Jan 22, 2008 | SAMTRON 55V 15" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
134 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
