Question about Kenmore 24032\24036 Top Load Washer
Model 110.22952100 Kenmore Elite Heavy Duty Washer
The agitator isn't working. It is making a loud buzzing sound
  • wea5 Aug 12, 2008
    Wash machine will not pump out water or spin during the spin cycle. Called the repair man and he replaced the coupling for 91.00. Trust me it is a 2 min. job if you tip the machine back unclip the pump take 2 small screws out that hold the clips that secure the motor. Motor will slide right off and you can pry the coupling off with a screw driver. My second problem is that it is also leaking oil from the outboard shaft seal on the gear box. Removed the other half of the coupling and tried to tap on seal with a small brass rod too seat it. Put it back together and it ran fine for one load then stoped again. Same symptoms as before but it also kicked out the breaker this time. Found out from wife that it did it the first time also, so I remove pump and motor again. Motor spins free but the gear box spins until the clutch grabs and then jams overloading the motor and kicking out the breaker. Is it worth it to call the service department again for i'm sure well over 150.00 to replace the gearbox and or clutch plus the labor or just buy a new one!!!!!!! ********** and disappointed with sears products.
How to remove agitate from a kenmore elite
Posted on Oct 03, 2008
  • 868 Answers
Motor is bad.Replace the motor.
Posted on May 22, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Kenmore elite heavy duty top load washer
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,299 people viewed this question
Sal De
 Brian Main
Brian Main
