Question about Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT COD/WIRE Multimedia Projector
Problem Will not come into focus . The covering around the lens is loose all information comes out blurry no way to adjust it properly .
  • 563 Answers
Check my answer to your prevoius posting.
Posted on May 22, 2008
Got no picture all blurry
No picture or one that is all blurry? If blurry,
Clean the lens and make sure it is not loose or damaged. The camera cannot produce blurry pictures at distances greater than around 0.3m ish as it has a fixed focus lens. If it really is blurred either you are too close to the lens, the lens to sensor distance is wrong (mechanical damage) or the lens is dirty.
I hope that helps
Jan 26, 2011 | Microsoft VX800 Webcam
Lens adjust is sticking. With the lense out you
since you have then lens out, get a wide blade flathead and insert it in the smallest part if **** that it will fit into behind the focus ring and turn the blade like you are trying to widen the **** all the way around until it pops out into it's normal position. Getting the entire lens back in properly is a bit tricky since the threads are easily stripped. First screw it all the way back on and then check the focus on the screen. You want to see a crisp image in 3 if not 4 of the outer corners of the screen. It is best to use something with text that fills the whole screen so you can see the 4 corners as you adjust the focus. If the focus is good in the corners, leave it alone. If not,hold the back of the projector in one hand and forcefully push the lens into where you screwed it on and see if it pops into place. It really is trial and error. Once you have a clear picture it is a good idea to remove the top cover and glue all around the base of the tube where it screws on so it doesn't come loose again.
Jul 30, 2010 | InFocus LP70+ Multimedia Projector
Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
SD TECH
Sep 14, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Jvc av65wp55 out of focus
When you say you changed the focus block, did you adjust each color individually ? Most projection sets are adjusted by covering 2 lens and focusing each one seperately. Try this , it has always worked for me
Sep 04, 2009 | Hitachi 46F510 46" Projection HDTV
The image is blurry and doesn't focus.
I believe the ring around the eye moves and will focus.
Apr 25, 2009 | Logitech QuickCam Communicate Deluxe...
Am not able to adjust the focus ring in my webcam
USE THE CONTROL PANEL TO ADJUST RESOLUTION.NO CONTROL PANEL?DOWNLOAD FROM FACTORY WEB SITE.RICHARDM69
Dec 12, 2008 | Logitech Webcam
Focusing
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
Focus on zoom
it is not the ccd problem .
the lens adjustment and ccd have no relation.actually when optical unit was replaced ,it is not fixed properly and due to internal lens de-adjustment.you would find blurry images on zooming.
it must be re-adjusted.
Mar 14, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Blurry pictures
have u ever send the camera to repair??, that cameras had a faulty lens, and need to be replaced our be repaired. good luck
May 17, 2007 | Olympus Camedia D-425 / C-170 Digital...
247 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
