Question about Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT COD/WIRE Multimedia Projector
Focusing Hello!!!!! We are having a problems focusing the toshiba projector . The covering around the lens is loose. While viewing information from projector to the screen ,the information is blurry and can be adjusted for proper viewing .It is a Toshiba TDP-S25
  • 563 Answers
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
Posted on May 21, 2008
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
Can't get slide projector to focus with lens in projector
Check the lenses inside the lens tube and see if they are loose or out of place
Feb 05, 2014 | Kodak 4200 Slide Projector
The film stuck when I feed it
This is a common problem with these projectors. Usually happens after a film breaks or a bad splice goes through it. Pull the lens straight out and then remove the lens housing that holds the lens and the focus controller. The screws for the housing are behind the glued on cover that says frame and focus. Remove the 4 screws behind it, slowly lift the cover and watch for a loose leaf spring that sits behind the cover. It will fall out if the projector is standing up, so lay it on its back and it will just sit there so you know where to put it during assembly.
Mar 26, 2013 | Canon Ps-1000 Canosound Super 8 Projector
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
The lens projector was pushed in and does not turn enough to adjust the focus.
hello therese prof, Hi, the lens is out of alignment, this could be aligned by disassembling the unit up to only on the outer part. of the case. once the cover is removed, you can re align the focus lens. no need to totally dismantle the entire unit. the lens is a separate passive device not connected to the electronics board.
Mar 03, 2011 | NEC LT265 Multimedia Projector
Lens adjust is sticking. With the lense out you
since you have then lens out, get a wide blade flathead and insert it in the smallest part if **** that it will fit into behind the focus ring and turn the blade like you are trying to widen the **** all the way around until it pops out into it's normal position. Getting the entire lens back in properly is a bit tricky since the threads are easily stripped. First screw it all the way back on and then check the focus on the screen. You want to see a crisp image in 3 if not 4 of the outer corners of the screen. It is best to use something with text that fills the whole screen so you can see the 4 corners as you adjust the focus. If the focus is good in the corners, leave it alone. If not,hold the back of the projector in one hand and forcefully push the lens into where you screwed it on and see if it pops into place. It really is trial and error. Once you have a clear picture it is a good idea to remove the top cover and glue all around the base of the tube where it screws on so it doesn't come loose again.
Jul 30, 2010 | InFocus LP70+ Multimedia Projector
Check my answer to your prevoius posting.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
Display shows dark shadow around the center
Have you checked your lens assembly? maybe loose, or the bulb may not be seated correctly giving on out of focus image.
Feb 01, 2008 | ASK Proxima C180 Multimedia Projector
Out of focus...
please read manual above.
Oct 25, 2007 | Toshiba TLP 261 Multimedia Projector
Camera Problem with Toshiba TLP 261
hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: good luck
Mar 27, 2006 | Toshiba TLP 261 Multimedia Projector
332 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
