I'm having problems with the Samsung 245BW. I bought the first one at Sam's Club and it developed some pixelation problems, i.e. blue and yellow horrizontal lines across the screen. I returned it to Sam's and they swapped me out for another one. Almost immediately, within a couple days time, it developed the same problem. I contacted Samsung and they sent me another one. Again, withing a couple days, the blue horizontal pixel lines are beginning to show. Now, I'm thinking, "3 out of 3 of these monitors have the same problem and perhaps its time to exchange it for another model of monitor." I'm curious what someone else thinks about this phenomenon. Plz get back to me ASAP with any suggestions. Thanx in advance. Wulf Strikin' out with the Samsung 245BW
  • 36 Answers
you can try this ,
check the monitor on the different wall outlet/ socket or check with different computer wheather it gives the same issue .. third option is check with both DVI and VGA ports differnetly.. please check wheather you are getting lines on the bios screen when u start the system because if you r getting lines on the BIOS screen (f1) then there is a issue with the monitor else issue with the video card ................try this ,if possible revert for the same issue
Posted on May 21, 2008
Samsung syncmaster 245bw powers on but there is no display.
check your rgb chord found at the back of your monitor, i think it is color blue chord that connects through cpu and monitor..push it tight and it will display again..
i hope it can help you
Jul 25, 2011 | Samsung SyncMaster 245BW Monitor
Samsung Syncmaster 245BW displays no image. Unit receives power and the blue LED on the power button is lit but the screen is not illuminated. I can't tell if the pixels are changing at all, but there...
laqbot7000, If you have opened unit, what is the brand name of capacitors (electrolytic's) printed on them. CapXon, Elite, Jun-Fu, are some you don't want to find on the smps board. Are any of the rubber seals pushed out of the bottoms of any capacitors? Is fuse still ok? Did you use a magnifying glass or low power "inspection" microscope(5x - 20x) to possibly find any "thinner than hair" fractured solder connections to component leads soldered to the copper foil circuit traces?? Also "visual" the black bodies of all solid state (transistors, bipolar, mosfet) devices for "burns" and "distortion" from overheating. 12fixlouie
Sep 21, 2010 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
My Sam sung TV has a pixel problem how do I fix it? What do I need?
Pixel problem? do you mean one pixel does not display or the picture is poixelated. like they do when TV stations blank out a face for privacy?
Sep 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Color noise suddenly appeared on screen, blacks show blue noise lighter colors yellow noise
You may have a poor connection with your LVDS cable which connects from the internal main board to the screen. This will either need to bre-seated or replaced.
Sep 23, 2009 | Samsung SyncMaster 245BW Monitor
Lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
Jan 01, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Samsung LCD HDTV - Color Problems
voltage adjustment for y-sus board or power supply
Mar 17, 2008 | Televison & Video
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Yellow and blue lines on 245BW
well, my monitor is going back to samsung for a replacement unit. I plugged in my monitor in a bunch of other PCs and it's doing the same thing regarless of the PC or graphics card I use. Now I know it's the monitor. Getting it RMA'd with Samsung. Only had it for 18 days. Hope they send me a new one and not a refurb.
Nov 21, 2007 | Samsung SyncMaster 245BW Monitor
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
