Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power cable problem for SHARP AQUOS TV 42 inch
Jerry,
I think my problem is not well defined. I will try again.
1. My TV works with 110v and 220v. This is indicated on the back of the TV and in the booklet of the TV. The booklet says that I need to contact an address to get a 220V power cable if I intend to use it in a 220v country. I did not write to this address yet. I believe they are selling a power cable which has european style plug. I already purchased a plug converter (USA style to European style) to attach to the 110v cable plug, so that I can insert it to the European power outlets. My concern is if the 110 v cable I have can carry 220v.
2. I know that my TV's tuner can accept only NTSC TV broadcasts. But there is a solution for this. I will buy an external PAL TV tuner from Turkey and will connect it to this NTSC TV by using the VGA output of the external TV tuner. My TV has a VGA input. As you know, if you give a video input to a monitor/TV, through a VGA cable, it doesn't matter if it is NTSC or PAL. I made experiments to see this result and it works.
3. Can you answer my power cable question? Does my cable can carry 220 v? I am asking this question with a hope that it works, because I am using 110v cables of my laptops in Europe with 220v (by attaching a plug converter (not a power converter) and it works.
Thank you for your help.
Zafer
    Genius:
  • Sharp Master
  • 1,689 Answers
The voltage rating of the cable is not a problem. For all home appliances, including TV sets, the voltage rating of the power cable is supposed to be up in the 600 Volt to 1000 Volt range depending on the particular manufacture of the cable. This is not an issue. I have never seen a home appliance that could handle more than 240 VAC.
As for the Amperage rating of cable, it is more than adequate for the appliance that the cable is sold for. The 220 Volt appliances use about 1/2 the amperage that their equivelent 120 Volt appliances use. This is because the wattage for the power consumption is normaly constant.
The power cable is not a factor here. If the power supply in the TV can take the 220 VAC, and the 50 Hz power line frequency then there are no problems from that point.
Jerry G.
Posted on May 21, 2008
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a 42 inch sharp aquos i dont have a remote and i'm trying to set my cable channels there is no way i can pull up a menu or nothing from the tv what to do
check ur tv as there will be buttons there where u can set programs and fine adjustments without remote control......if u still have probs ......get yourself a new remote control.......
Nov 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Need power cable for SHARP LCD TV to use in Turkey
It is not the power cord that makes the rating of the power supply. You can use a transformer, and not a solid state converter to lower the 220 V to 120 V.
What you will find if this is a North American TV set, it may not work in other countries due to the standards for TV broadcast.
If the set is rated for PAL, this will only work with the video inputs, and not the tuner. The tuner frequency allocation and the video and audio carriers are also different between the some of the different countries.
Jerry G.
May 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos 42"
Check the settings in the TV set for HDMI sound on the input of the TV that you are using. Try another HDMI cable. It may be defective.
It is also possible that there is a compatiblity problem for the HDMI sound between the TV and the computer's sound protocol.
Jerry G.
Apr 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
457 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
