Toshiba Satellite Drive
My DVD drive face plate is loose and the drive will not lock closed now. Can this be repaired or do I need to replace the whole drive?
  • 111 Answers
If the mechanism that holds the tray is damaged, you have to replace the whole drive.
Posted on May 21, 2008
Toshiba disk drive mk6028gal
The hard disk drive (HDD) in your Toshiba laptop is the component that holds all the files and folders you use.
If you are running out of room on the hard disk drive because of all the programs you have installed, it may be time to replace it with a new one that has a larger capacity.
Replacing the hard disk drive on a Toshiba laptop is a fairly straightforward and simple process, as you only need to remove one other component to be able to reach the hard drive.
Save a backup copy of any file or program that you will need from the original hard disk drive to an external device such as a CD-RW or USB flash drive.
Shut down the Toshiba laptop's operating system completely.
Disconnect the power cable if it was plugged in and then close the top screen lid.
Flip the entire unit over so that the bottom end of the laptop case is facing towards you.
Hold down the release latch for the Toshiba laptop's battery.
Slide the laptop battery out of the case and then put it aside.
Locate the screw at the upper-left corner of the case that holds the CD or DVD drive into place.
Remove the screw and set it aside. Grab the edge of the CD or DVD drive and then pull it away from the Toshiba laptop case. Set the drive aside.
Remove the four screws holding the large square plastic cover over the hard disk drive at the lower left end of the laptop case.
Lift the square plastic cover off the laptop case and set it aside so that you can see the metal plate that covers the hard disk drive.
Take out the screws holding the metal plate in place.
Lift the metal plate out of the case and set it aside.
Remove the two screws at the top edge of the hard disk drive and then the two screws at the bottom edge of the hard disk drive.
Disconnect the hard drive from the motherboard by sliding it out towards you.
Lift the hard disk drive out of the case and set it aside.
Push the new hard drive into the open slot and then reconnect the four screws.
Set the metal plate back on top of the new hard disk drive and then attach its screws.
Put the plastic cover on and reattach the cover's screws.
Slide the CD or DVD drive back into its port and then reconnect the screw.
Put the battery back into the Toshiba laptop.
Turn the laptop over and open up the screen.
Power the computer on. Insert the recovery disk that came with the Toshiba laptop into the CD or DVD drive.
Follow the operating system installation instructions that will appear on the screen.
Transfer the backup copies of the files you saved earlier from the external device to the new hard drive.
Toshiba Satellite hard drive replacement
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Aug 13, 2013 | Computers & Internet
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
Disk drive does not work. Possibly need a driver. What kind of removable drive? Rewriteable DVD written on face. Toshiba Satellite A15 series bought quite a few years back. Windows XP home.
I would go into the BIOS and make sure that the correct drive and drive type is there. Up on the boot sequence, hit F2 and go into the BIOS.
Also, go to the toshiba website download the drivers you need. I do it all the time.
Jan 18, 2011 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Actually my dvd is not opening when i m pressing the open/close button.
It could be a "physical" problem.
Take a Norwegian paper-clip, and straighten one end.
Insert that end into the small hole in the face-plate of the drive,
and push until you feel resistance.
Then, firmly push another 10mm (1/4 inch) and the drive should "unlock" and open slightly.
Press the open/close button to fully open the tray.
Dec 11, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
I need a replacement optical drive for the Toshiba A45-s151. I've googled for an hour and can't find a simple list of possible replacements. Any ideas where to look? Thanks in advance.
The "good" news is that laptop CD/DVD devices are "generic", i.e., just buy a new one, and it will fit, once you remove the face-plate from the old drive-tray, and connect it to the new drive-tray.
However, replacing a CD/DVD device in a laptop is not a "beginner-level" do-it-yourself project.
Take the computer to a computer-store, and pay them to disassemble your laptop,
remove the old drive, connect the replacement drive, reassemble your laptop, and test it.
Nov 12, 2010 | Toshiba Satellite A45-S150 Notebook
Need to replace dvd drive, not sure how to remove it from Toshiba Satellite 1415 S105
you would see latch when you open the plate in back using screw driver just pull it and drive will slide out........dont be harsh on it
Sep 01, 2009 | Toshiba Satellite 1415-S105 Notebook
Replace DVD/CD drive on Satellite A105 notebook.
Ther is probably a single swcrew that releases the entire DVD/CD drive and it pulls out. Check your owner's manual or go to Toshiba's website and download the repair/trouble shoooting/owner's manuals and they will tell you exctly what to do.
DELLS usually have a screw insode of the memory access plate or under the battery after it is removed, but I odmn't know where they are on Toshibas.
Don Jones
Jan 28, 2009 | Toshiba Satellite A105 Notebook
I cannot open my Toshiba Satellite 2805 S301 DVD-ROM drive.
Hi Packman,
right click the DVD drive, an choose "push it open" -> direct translated from Danish :-)
. but I´m sure you´ll find it.
regards
/Teis
Dec 16, 2008 | Toshiba Satellite 2805-S301 Notebook
Toshiba Cd drive won't close
There must be a small part locking mechanism that broke or lose thread inside your dvd drive. gently open it and you will see it.
Apr 20, 2008 | Toshiba Satellite A70 Notebook
DVD Drive Broken: How to replace?
Turn the Laptop over and there will be a clip or maybe a screw with a picture of some CD's next to it.
The website of the laptop maker will be able to show you, or post the make and model and we will try and help
Mar 31, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
David Payne
David Payne
