Question about HP Pavilion zd8000 Notebook
No fan of three fans!
My zd 8000 is a fine computer. Nothing is wrong but... the noise. When i start the computer it won't take long before all three fans start blowing even when i am not doing any tasks whit it.  It' a good thing to see and hear the processor is kept cool but is it necessary to cool so hard when you are just reading mail or so?
Is there anyone who knows if there is anyway to regulate the fans or underclock the core ( i use the laptop mostly for mail, internet and Word. That's also why the noise is so annoying! You lose concentration! )
I'd appreciate any kind of help. Ton
  • ton4sure May 21, 2008
    Thanx! now i can see what's happening. It's working at 3% CPU and i am reading 40C at sensor 0 and 66C at sensor 2.!
    Its sweating for nothing!
    Fooling around whith the fanspeeds dousn't seem wise at this stage. So i went looking at lowering the FSB speed . I don't know what mainboard or PLL manufacturer and type to put in the windows. So i can let CPUcool do it's own work. It gives me ICS/ 9148-04 for PLL.  The given FSB calculations ,however, do not work! CPU cool states that 8 bytes were found where there schould be 6.
    Now I'm stuck. Any Idea's ?
    My PAvilion is to be precise a ZD 8320EA s/n CNF5480SWN
  • 242 Answers
YOu can use software like CPUcool to monitor and manage your system. It uses temperature sensors (if available in your laptop) to measure temperatures, and has features to manage CPU speed and some more.
Posted on May 21, 2008
  • Thx_nb May 22, 2008
    It didn't actually give you ICS /9148-04.
    Those are just the first options of dropdown box.
    Finding the information is not as easy on a laptop, since a desktop is easier too disassemble.
    Actually, at what frequency is your CPU running?
    My laptop has a dual core 2.0 ghz, but it automatically lowers freq to 1 ghz if it is not busy...
    I will look if i can find the information you need.
I am hearing a little bit of squealing noise when running the ventilation fan in my house.
Sounds like you have a bearing going in the blower unit or a loose belt. Get it serviced by a reputable service company.
Oct 20, 2014 | Carrier Weathermaker 8000 Gas Furnace 125k...
Noisy side by side hot point. It has been keeping us up at night. Repair man says nothing wrong. It was not this loud when new three years ago. Any thoughts? Model # HSM25GFTA
Often the noise is the condenser fan underneath the frdge... the bearings get worn and then the fan starts to make a horrible racket...see if you can pin the noise down to that and then order a repalcement...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 08, 2010 | Hotpoint HSS25GFP Side by Side...
Kenmore 8000 BTU A/C runs, but won't blow air
Sounds like a problem with the fan. There maybe something caught in it. If you had it stored is an outdoor environment then some wildlife (rodents) may have nested in it. You need to remove the cover and do a visual inspection. If nothing is caught in the fan then try turning it by hand and see if it spins freely. Some units have just 1 motor that turns the evaporator and condenser fan blades; others have 2 seperate fan motors.
Jul 07, 2010 | Kenmore 75051 Wall/Window Air Conditioner
My computer started making a loud noise that will not stop. I am not sure if it is the fan or hard drive. The computer seems to be working fine. Any idea what could be making the noise?
In order to confirm the problem.. first of all turn off the pc and unplug the power cable from the back of the pc.... get a Philips head screw driver and open the chasis.... plug in the power cable and see where are you getting the noise from .... there are three fans namely one on the processor, the other a cooling fan and the last would be inside the power supply.. if its inside the power supply nothing can be done ... if its the cooling fan noise .... try to clean the vents or the cooling fan with the help of the dry cloth and if its the processor fan then its a serious issue ....
Apr 12, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
The fridge is working fine but there are intermmitent noises from the motor? How do I trouble shoot this problem?
lot of them do it sometimes you can just shack it a little and it stops. there is nothing wrong . maybe the rubber on the compressor got moved a little. if oyu have moved the unit.
Sep 21, 2009 | Fisher and Paykel Active Smart E522B...
I have an hp pavilion zd 8000 that does not boot
Hp has a really good on line chat to help with problems. What windows version XP,VIsta or other so on What part of the screen does it stay at. Not enough info. Can you what key options on side or bottom of screen to change to a bootup screen like F8. Tapping the key when the 1st screen appears till you get to a boot page . Then select last good configuration with your keyboard arrows the hit enter. This should reboot and see if it reconfigures to run.
Aug 31, 2009 | HP Pavilion zd8000 Notebook
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
OPENING THE CASE FOR HP PAVILLION ZD8000
Hi all
I have made another guide than the one that was removed from the net.
cleaning your hp zd 8000 in 9 easy steps... with photos and detailed a description.
how to clean a zd 8000 notebook
here is the link : http://www.realsancristobal.com/myguides/how_to_clean_a_hp_pavilion_zd_80.htm
hope it helps someone out there
Peace
Nov 10, 2008 | HP Pavilion zd8000 Notebook
Noisy fan after a few minutes start up
Yeah. i had this problem too. the fan is noisy because it is garbage. it needs to be replaced if you want to get rid of the noice. you moving the laptop wen the noise first started is just coincidence. the heatsink is fine, but the fan itself is poorly made. The ball bearings get loose and so the fan doesnt stay in its vertical plane and it kind of shakes a little, thats why it makes the noise. if you open it up and turn your laptop on, and wait for the noise, you will notice that if you push down lightly on the center of the fan, the noise goes away, because you are creating pressure at it's center of gravity point which makes it stop wobbling. you wont see the wobbling with the naked eye, because its much to slight to see, but its definatly enough to make that annoying fighter jet take-off noise..
as far as the noise, thats the sound it makes when something is wrong with the battery (if you ever drain it all the way down and try to boot it, it will make the noise) kind of messed up noise in my opinion, but its not a big deal, as long as it doesnt repeat.
for the fan, you dont need to replace it if you dont use your laptop a lot, you can try to keep your laptop cooler to keep the fan from turning on also. i suggest one of those USB fan pads that you put under the laptop, or a thermal pad, thermapak makes one for $30 i think, and it drops temps by 6 degrees celcius they claim, i dont know exact numbers but if def helped me. you can also try to put something in the back to keep the back elevated (where all the heat is) and the fan wont spin as much.
i know with desktop fans that get lots of use, noise is the 1st sign of fan failure to come, but ive been using my laptop with that god awful noise for about 4months now, and its still alive and kicking.
good luck!
Aug 24, 2008 | Acer Aspire 5100-5033 Notebook
HP Pavilion zd8000 Notebook Logo
230 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
