Question about Olympus Cameras
I have Olympus FE-140 camera Purchased november 2008 it was used for a short time then put away until a few weeks ago. WhenI went to us it again it kept showing "CARD COVER OPEN". I have checked and the cover is definitely closed .Can you help?
  • Danielelleli Jan 25, 2009
    i have this same problem, i don't know if its just the sensor or something. please help. resetting didn't work either.
  • 790 Answers
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
Posted on May 21, 2008
When I change my AA batteries, I lose my date and time.
Hi there!
You can still set the date and time for this camera. Just follow the steps found on this website: Set Date and Time for Olympus FE-140.
Best regards!
Jun 12, 2011 | Olympus FE-140 Digital Camera
Same problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 08, 2009 | Olympus FE-230 Digital Camera
I purchased an olympus fe-330 8.0 megapixel camera about a month ago and worked ok until about a week ago when it just wont turn on. i have tried to charge the battery but the red light only comes on for...
when the red light is off, it means it is fully charged.
May be you are puting it wrong side in the camera. check the arrow to put in the camera
check with the service centre.
Jul 10, 2008 | Olympus Cameras
Olympus digital camera FE-140
Usually it just means that you have to start you camera after its shut off and connected to your computer. that should fix it. Hope this helps. =)
Feb 25, 2008 | Olympus FE-140 Digital Camera
Camera problem =/
In addition to the one year World Wide Warranty,
issued by Olympus Corporation in Japan, the European warranty, issued by Olympus Imaging Europa GmbH, is
valid for two years from the date of purchase, if purchased after 1st April 2004
Oct 06, 2007 | Olympus FE-140 Digital Camera
Broken camera
Oct 03, 2007 | Olympus FE-140 Digital Camera
Camera batteries drain quickly
Open the battery door and check the contact between the camera and the batteries. Most often then not there is just a bad contact and it's ruinning your baterry life.
Make sure that the contact are well placed and that there is no rust or dirt build up around there.
Sep 23, 2007 | Olympus FE-210 Digital Camera
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Olympus Problem
If you mean that it is a new camera - then returnit to the seller for replacement as it seems to be an internal fault.
Aug 20, 2007 | Olympus FE-230 Digital Camera
Olympus FE-140
just use recharchable bateries and if u don´t use the camera take them out, and u are right this cameras just drain batteries out, use a powerfull rcharcheble batteries, over 2000 mAh
Dec 28, 2006 | Olympus FE-140 Digital Camera
Cameras Logo
249 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
