Question about Dryers
Dryer stopped working
Our dryer just stopped working. Maytag Performa. No power indicated at all. The power at the outlet is good. Could this be the thermal resister? or some other fuse inside the dryer?
  • delllaa May 21, 2008
    IS there a simple way to check that?
  • mitch62 Jun 21, 2008
    My dryer (Whirlpool LER7646EZ2) will not come on. Door is shut. Timer sounds like it is "timing", but the dryer will not come on. Let it cool, checked circuit breakers, etc. and still will not come on.
  • 868 Answers
Yes it maybe a fuse problem .But first you want to make sure the door switch is working.
Posted on May 21, 2008
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
My dryer stopped mid drying cycle. The breaker in
Your dryer has an overtemp safety. Called a high limit, it has 2 wires connected to it, and usually is held in place by 1 screw. There will be a couple of them, the one closest to the element will be the bad one. It looks like a suppository, you'll see if you open up the unit yourself. DISCONNECT ALL POWER BEFORE ATTEMPTING ANY ELECTRICAL REPAIRS!!!!!!!!!!
Apr 11, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
Dryer won't turn on
sounds like the bearings on your motor are going bad
Dec 12, 2008 | Maytag Performa PAV2200
Performa Washing Machine Not Working
CHECK YOUR OFF BALANCE SWITCH ,IF YOU SAY IT DIE BEC. TO MUCH IN IT ,IT COUL BE THAT OR FOLLOW YOUR WIRE YOU MIGHT HAVE BURN SOMETHING.SWITCH YOUR DRYER PLUG TO YOUR WASHER ANYWAY,CHECK THE LINE CORD IF THE TIPS ARE MAKING CONTACT.
Nov 06, 2008 | Maytag Performa PAV2200
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Dryers Logo
214 people viewed this question
Top Dryers Experts
