Question about Nokia 6630 Cellular Phone
Memory card problem
My mobile got switched off by itself and after switching it on now it says memory card unavailble even though its there i dont want to lose all the info stored in my card plz help
  • 1 more comment
  • meenz May 21, 2008
    thanx for ur reply but how do i format the card and will i be able to copy back the contents to my card after formatting it?
    i tried connecting it through a card reader but it doesnt read the card does it mean my mem card is corrupted?
  • asimpk
    asimpk Jun 21, 2008
    well i am having same problem but with a bit different !
    My Phone dose not change my messages memory on memory card.its just stuck on to phone memory, and also giving the error message i.e."memory low" even its about 8mb memory is free there.
    what have i done till now is
    I bought new memory card but its not working properly,"Unable to find memory card" error shows.
    I did refresh my phone manualy and also with this code *#7370#...
    but the problem remains same....
    over all problem is changing memory !!!
  • 790 Answers
Connect it to comp and copy the card contents ... and format it !!!
Posted on May 21, 2008
  • Kanth raj
    Kanth raj May 21, 2008
    Yup u can copy back ... just connect it to comp and right click on it and format!!!
  • Kanth raj
    ya try diff reader once ... not sure abt the card worn out!!
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
When iam copying any thing from my pc to my mobile It shows error copying file or folder make sure that the disk is not full and write protected and file is not in use..... but they all are wrong...
check the memory card if its working fine. the memory card might be corrupted thats why it aint accepting any files coming in from your PC at all. hope this helps
Feb 12, 2011 | Computers & Internet
My nokia 6300 gets switch Off and On itself, it continues to happen abt 4-5 times. If one switch it off and then switch it on, then it takes abt 7 minutes to start functioning. At times, it even gets...
hi
there will be virus in your memory card.please try to format the memory card.then format the phone with new OS. this will probably prevents hanging of your mobile.these hangings are happening due to virus programs.kindly be alert.
thank you
Dec 17, 2010 | Nokia 6300 Cellular Phone
My micro sd card is write protected.....i dont use any adapter though...?
Most SD memory cards have a write protect slide switch on the edge of the card. Move the slide switch to the read/write position.
Aug 29, 2010 | SanDisk 2GB microSD Memory Card
My memory card getting automatically removed from the phone giving error msg. uasafe to remove memory card withou selecting "remove mem. card" first......... autometically
hmm...reset ur mobile (w/o mmc) and after that..switch off fone,insert memory card and start.. <even i had same prob but now solved >
Jun 15, 2010 | Nokia N73 Cellular Phone
I have nokia 3500c and its music player doesn't start though there are lots of music files
it takes nearly 10 minutes to scan the memory card when u start player, during this time phone will be hanged, be **** nd keep quite. once scan is over the player will start normally fast from next time onwards. but is u restarted ur mobile phone it starts scanning.
advice dont switch of ur mobile
dont use 2 gb card as it slow downs ur mobile
Jul 10, 2009 | Nokia Cell Phones
MY SAMSUNG D880 KEEPS REBOOTING
check did you have memory card "bigger than 1 gb" installed
than remove memory cards,sim cards too
after removing its - start phone and perform full reset with code.
dialing *2767*3855#
but in your phone it will look like *2767*---- after clicking # phone will start full reset
after that return your cards in phone and start using it as new one.
Jun 09, 2009 | Samsung SGH-E251 Mobile Phone - Black
Phone restart
this problem can be overcome by formatting ur memory card by ur phone itself or by using card reader in personal computer..............and also dont add too many themes and dont change d themes often
May 10, 2008 | Nokia 3110 Cellular Phone
Automatic Switch off
i have a mobile of nokia 3110. i found a problem in it that it suddenly restarted again and again ?is it any virus problem or any thing else? if yes where i found its anti virus plese suggest
May 09, 2008 | Nokia 3110 Cellular Phone
Card Locked
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 26, 2007 | Praktica DCZ5.0 Digital Camera
Nokia 6630 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
