hi there,
i have a kenwood rx 28. now and again i would switch on, everything would be on, but the graphic eq wouldn't register any sound (it wouldn't move) going to it and there's no sound apart from a little distorted sound if you turn the volume up full. it used to be remedied by changing the batteries in the remote!!!??? sometimes it would work if left alone for a day,but it happened again yesterday and it isn't working. Please help as i now use it for my pc and writing music.
-   Well i have the same problem but what you can try tho is to unplug equalizer from the back of the base unit and replug it again. do this with the music playing all of the time.-   Guest
Hola: el problema es que el aparato enciende, pero pasados unos cuantos segundos de sonido, este se...
(More)
Hola: el problema es que el aparato enciende, pero pasados unos cuantos segundos de sonido, este se apaga repentinamente. Ya un técnico le "repaso" todas las soldaduras frias del aparato, pero aun asi este sigue apagándose. El problema esta en el AMPLIFICADOR DE POTENCIA / ECUALIZADOR GRAFICO, y al no funcionar este, todo el aparato se detiene. A veces al apagarse como que se pega y emite un sonido de apagado/encendido continuo y este aumenta su velocidad, y hay que desconectar el aparato. Si alguien puede ayudarme le agradeceré enormemente. Francisco / Cartago-Costa Rica.
I have the same issue B-B5 turns on and off. I have sourced a replacement unit but it is a B-B7....
(More)
I have the same issue B-B5 turns on and off. I have sourced a replacement unit but it is a B-B7. Does anyone knoe if this unit will be compatiable with my UD-551M midi system?
We have just been given an old Kenwood Hi Fi (DF-A9), but we can't set the time, there seems to be...
(More)
We have just been given an old Kenwood Hi Fi (DF-A9), but we can't set the time, there seems to be no clock setting function on the stereo or on the remote control?????
Turn power supply on and PROTECT is displayed. Cannot turn stereo on. PROTECT automatically switches...
(More)
Turn power supply on and PROTECT is displayed. Cannot turn stereo on. PROTECT automatically switches whole unit off. Why and how can this be fixed please.
Hi there, Friend of mine has a Kenwood UD-551M hi-fi stereo used for more than 10 years, but its...
(More)
Hi there, Friend of mine has a Kenwood UD-551M hi-fi stereo used for more than 10 years, but its stopping work suddenly. When I pressed power key from power amplify, there was a pi pi pi sound constantly until I pressed memory key and then the sound was stopped. Could anyone have some idea and suggestion with this problem and thanks. Margaret
