Question about LG Flatron L1710S 17" LCD Monitor
Dead as a dodo.
When I power up the unit, the power switch illuminates (green) but nothing else. I've checked the (two) pcb's for obvious signs of damage but theye are pristine in appearance, all tracks in tact and no obvious signs of heat damage..
Does anyone have a service manual for this item, or perhaps details of voltage checks I can perform?
  • Chris Dermott May 22, 2008
    Further to my original "Dead as a Dodo", I can't help negatively commenting on LG. I've been to their website and WASTED over an hour trying to actually locate someone to get information - don't bother you'll (like me) end up going around in circles and get absolutely nowhere - it's obvious they don't want to talk to you!
    In addition (I'm sure) that the LG service manuals have been produced to raise the blood pressure of any engineer trying to use same, E.g The Flatron 1710S (CL-42 chassis) I've been looking for, finally managed to download a service manual for same which turned out to be the LB700G-GD & GU and (guess what) power supplies are completely different - no surprise there! So manages to get hold of the 1710B (same CL-42 chassis) which (as it turns out) has the same power supply as installed within mine and guess what, NO SCHEMATIC for the power supply even though drawings exist for all the rest of the electronics - WHAT???
    I give up! How the heck are you supposed to service kit when the required information isn't available? For the amount of hassle I've had in just trying to get this (most basic) info, I've a good mind to throw this flaming monitor in the bin. What a waste of time - not impressed!
    Whew that's better - needed that!
  • gsrnadeem Jul 22, 2008
    I have the same problem. the power light goes from abmer to green when I reboot the PC, and the monitor start as rebooting, but there is not data shown on the screen.
    Not sure about that solution, how can I know which Caps is dead, and should be replaced ?
  • 558 Answers
Have you checked caps to see if they are blown I replace caps constantly on lcd monitors and they have all come back to life. let me know if this helps
Posted on Jun 19, 2008
Replaced the power supply TV was completely dead no blinking nothing replaced the power supply got green steady light but no sound or picture just green light fans TV stays on until i shut it off remo
ReCheck the connections.if the original power supply burnt out due to a short or system failure then you will need to check all the module boards for any evidence of burning.check the capacitors for signs of swelling or splits as these are usually the cause of no life.also I assume the power supply was the right volt/ amp as this May have blown an on board fuse on the main pcb.
Jan 11, 2015 | Pioneer PureVision Pro-1410HD 61 in....
No power on ricoh 3245c
Check your laser unit and in particular the polygon motor.
There is a small diode on the pcb that blows and it gives you a similar issue to the one your control panel is displaying. LCD dead and only green soft switch light displayed on control panel.
There is a RTB for this.
Brother Printer Support
Jan 04, 2014 | Office Equipment & Supplies
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
Panasonic NN-651W microwave gone dead
There si a place called encompass parts that is a distributor for Panasonic, Look them up or call them with your model number and check price and availibility on the PCB
Oct 18, 2017 | Panasonic Microwave Ovens
Beko WMA765s washing m/c 'dead'
Hi press and hold the start button for about 5 seconds .see if this works if not you will have a faulty pcb which will need to be replaced hope this helps
regards dan
Mar 19, 2009 | Washing Machines
No power to the vaio
perhaps you cracked the board? I know I woulda broke it in half. A lil more info would help
Mar 08, 2008 | Computers & Internet
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
LG Flatron L1710S 17" LCD Monitor Logo
98 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
