ok goto bluetooth setup in blackberry
when it starts search hold bluetooth power button on this will sync the 2 together at the end it will ask for a pin
I could not get my LG HBM 770 headset to marry with my XV6800 - It
simply could not see the LG. Then I thought I would disengage it from
my old razr - was still keeping it charged and on so I could refer to
it for phone numbers.
It worked! And without holding the power button on - It just found it easily. But I am glad to have read ShaggyRat's tip on the code being 0000 - needed that to complete the process. Cheers!
the right speaker doesn't work unless i twist and push the wire in the speaker,i tried to take apart...
(More)
the right speaker doesn't work unless i twist and push the wire in the speaker,i tried to take apart but couldn't (i didn't want to force it)
My Insignia bluetooth headset (NS-BTHDST) does not connect properly to my computer using windows 7...
(More)
My Insignia bluetooth headset (NS-BTHDST) does not connect properly to my computer using windows 7 b4 bit. It paired once but kept disconnecting and reconnecting after about 30 seconds. Now, whenever it says it is connected no audio comes out of the bluetooth headset or from the laptop at all. Even when i connect a set of normal headphones no audio is heard. The audio comes back as soon as i disconnect the bluetooth device. Anyone else having this problem? I had this same problem on a 32bit installation of vista as well.
phone is switched on but screen will not turn on taken phone t bits and one of the ribbons is in 2...
(More)
phone is switched on but screen will not turn on taken phone t bits and one of the ribbons is in 2 bits is this normal or has it snapped?
