Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
SimpleDrive disconnect My SimpleDrive 250 GB keeps saying it can't stop my generic volume device because it is in use and to close programs and windows that might be using the device. I have eliminated all shortcuts, turned off my printer. What else? Note: I generally locate the problem, but cant now.
This is caused by the drive letter assignments done by XP and 2003 server. To stop the drive you will need to access Computer Management, Drive Management and locate the drive assignments for the partitions on the drive. Remove the drive letter assignments (has not caused any data issues in my usage). After the drive letters have been removed you can stop. After several calls with SimpleTech they finally said to just unplug without stopping if the drive will be used on the same machine again. If you are moving to another machine the only issue with not removing the drive letter assignments is that the current assignments may conflict with assignments for CD's or other drives on the new machine.
Posted on May 21, 2008
  • 37 Answers
Do you have an anti virus program installed int your computer and is it updated? then run a complete system scan. The problem occurs when some script or virus is active and running in the device which you are trying to stop. generally, completely scanning the system and removing any threats present solves the problem. Sure did worked for me. Give it a try
My Hitachi Simpledrive Mini 250 suddenly quit....when I lookein the device manager it said Code 10, would not start????
Sounds like a disk error and it cant read the start of the drive. If it still detects it you might be able to repair it with a partition recovery or partition repair tool available online.
Dec 11, 2014 | Hitachi SimpleDrive Mini 250GB USB 20...
I have used my USB... when im already going to unplug it using the "safely remove USB", a notice pops out that says: <the device Generic Volume cannot be stopped right now. Try stopping the...
Hello marieborja10,
This happens some times when a program is accessing something on the drive. Make sure all files that were opened are closed. Also, make sure any open folders are closed.
If it still fails to eject, it is perfectly safe to pull the USB connector out as long as all programs/files/folders are closed.
Hope this helps!
Jun 29, 2011 | Ritek RiDATA Ultra-M N-S25-256-M 2.5 256GB...
Message displays when attempting to "safely remove hardware"
You need to go to the Tool Bar, (bottom r/h side), and click on Safely Remove USB hardware. and choose your device and shut it down from here then remove.
Jan 29, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
When i click on "safely remove hardware" to unplug or eject the hard drive, i keep getting a msg that says "The device 'Generic volume' cannot be stopped right now. Try stopping the device later"... This...
As long as the activity light is not on/flashing and all programs using the drive are closed, it is OK to unplug the drive. If you want to be on the safe side, turn off the computer, then unplug the hard drive.
Jan 12, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
The device Generic Volume cannot be stopped right now. try stopping the device again later. on Window XP
If you tried to stop your external hard drive with it open in Windows Explorer, You will get this message. You cannot disconnect the drive in this condition. Even if you close Windows Explorer after, Windows still thinks it is open. The best thing to do, is restart Windows and when the screen goes black, shut the power off to the external drive or disconnect the USB cable. Disconnecting in any other way causes Windows to have problems with USB devices in the future.
Jun 08, 2009 | Western Digital 500GB My Book World...
Problem ejecting/stopping Seagate Freeagent Go 250GB hard Drive
Antivrius or another program using it...You just need to stop all servicess on task menager then stop mass strorage device
May 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
116 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
