Question about Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000 SC486
Can you tell me what this error code means and how to clear it.
Thanks
  • GerrieGTS Mar 18, 2009
    When I switch the printer on it shows on the LCD display SC486. I have not as yet not plunged to usb cable into the PC.
Realizar a troca do BK Solenoid.
Ele está localizado dentro do driver onde estão as engrenagens, ao lado esquerdo da impressora atrás da placa BICU
Posted on Jul 18, 2008
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
Code sc486
BK Solenoid Error : The BK solenoid cannot drive the black PCU
Engine board or Drive unit is probably broken
Jan 22, 2011 | Ricoh Aficio CL2000N Laser Printer
I HAVE A RICOH AFICIO CL2000 LASER PRINTER AND WANT TO SELL OR GIVE IT AWAY, BUT I HAVE A CONCERN ABOUT ITS MEMORY. IS IT VOLATILE OR CAN SOMEONE GET ACCESS TO INFORMATION THAT I PRINTED OUT PREVIOUSLY?...
Hi, the CL2000 has a hard disk drive, mounted on the controller board, where image data is stored temporarily. If you're worried about sensitive data, it's a good idea to have a technician remove the hard drive before you give the printer away.
Jan 11, 2011 | Ricoh Aficio CL2000 Laser Printer
Printer jams when printing and I ricoh cl2000n error code sc486
sc486 is a solenoid error with the black drum unit. The most likely culprits are a bad engine board and a bad drive unit, neither one of which is cheap unfortunately. You should contact your local service technician and have them take a look at the printer to see which component is causing your problem.
Dec 10, 2010 | Ricoh Aficio CL2000N Laser Printer
How do I reset the replace transfer belt message on a Ricoh CL2000
You'll have to replace the transfer belt with a brand new one in order to clear that message. Installing a transfer belt from another machine won't clear it -- it must be a completely new unit.
Jan 04, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh Afiicio CL2000 Color register error.
You can try to reseat the color PCU, but you may have to replace it. Also, make sure all of your color toners are seated properly.
Jun 28, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
983 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
