WHEN I ON MY HI FI SYSTEM THERE IS NO SOUND COMING OUT OF THE SPRAKERS, AND WHEN I INCRESE THE THE VOLUME TO 16 OR ABOVE THE HIFI SYSTEM AUTIMATICALLY TURNS OFF. TO RE START THE SYSTEM YOU HAVE TO TURN IT OFF FROM THE MAINS FIRST. THE MODEL NUMBER IS SONY HCD-WZ5 AND THE SERIAL NUMBER IS 6613423.
  • 2 more comments
  • tktcpa Aug 31, 2008
    no sound coming from system
  • Anonymous Mar 27, 2014
    REMAOT CONTROL
  • Anonymous Mar 28, 2014
    Serial number is 6989577
    serial number 6989577
  • 4,234 Answers
There is a problem with the output section. When you turn up the volume, the protection circuit kicks in and shuts down the system. This unit requires service. Expect a parts cost of about $10-$30. Add in the local labor rate for the total repair cost.
Dan
Posted on May 21, 2008
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
DVD tray not coming out fully and dvd disc tray not rotating and screeching sound is coming
it sounds like the "Tray" loading belt has stretched, You could try cleaning it, this would prove a point but will need replacing. the belt is small (about 20mm diameter) and is located under the disc tray near to the front, removing/replacing it will require the hifi to be dismantled.
Apr 07, 2014 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
I have vcr tape wont play in hifi all the time. and dose same thing in every vcr but has no other audio track
The hi-fi sound goes first. There is nothing you can do about it. Unless some special recording techniques were used, you always have a linear sound track too. Try to adjust TRACKING on the remote to hook up to the hi-fi track.
Oct 26, 2013 | Samsung DVD-VR357 Tunerless DVD Recorder...
Audio output to hi fi from d530 sff
Yes there is. You can use the same connector you use for headphones / speakers. You need a cable - type depends on your HiFi inputs could you specify what HiFi you have?
Although Jack-2xCinch (Male-Male) should work on standard HiFi towers.
Dec 31, 2011 | HP Computers & Internet
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
Sound volume knob does't respond
Chances are that it's a digital volume control.
The fact that it turns down again means it's probably fixable.
Open it up (switch it off first), and fetch a soldering iron. Look around for wires that go from the volume control and see if any are loose connections/broken wires etc etc. Solder these again, and it should work.
If you don't fancy this, take it to a hifi shop and they'll fix it for you (there'll probably be a fee involved)
Jan 13, 2010 | Teac DCD2831 Mini Hi Fi System w/3 Speed...
The speakers on my tv are done in , how can i get sound through anything else can i us a hi fi system
Your TV must have an adapter for output where you can connect the
cord to the input of your hi-fi system. Yes, you can use it, and control
the sound from your TV and Hi-fi. First, you must set your TV volume
to low position. Then, adjust the volume further at your Hi-fi to a
comfortable level. Let us know thru the e-mail and vote for our solution.
Sep 25, 2009 | Samsung P42H 42 in TV
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
Old Technics turntable got a buzzing sound
sounds like the input to your hifi is a line level input.to use an old turntable you need a phono pre amp to make it work.try maplins or a local independent hifi shop.
Jan 19, 2009 | Audio Players & Recorders
Game video input enabling
Dear krismedia
You should first confirm that Audio/Video output cable from the hifi is connected to the TV , then you should connect the game console to the input section in ur hifi system. And finally see if the TV is in AV mode and also see if the HIFI is detecting in the input mode.
Dec 12, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
149 people viewed this question
 Grubhead
Grubhead
