Question about Estate Refrigerators
Refrigerator cooling to 59 degrees in non freezer compartment
Estate model TT18AKXGW01 NOT COOLING IN NON-FREEZER COMPARTMENT WITH DIAL SET TO MAX ONLY GETTING 49 -59 DEGREES , FREEZER IS MAKING ICE AND SEEMS TO BE OKAY
    Scholar:
  • 57 Answers
If the fan is running you more than likely have a defrost problem.
Look at the back wall of the freezer section if it is frosted up. it's not defrosting. This keeps the air from circulating through the refrigerator section.
Posted on May 21, 2008
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
The Refridgerator compartment won't keep cool , but the freezer works fine. Would it be the thermerstat or compartment dial
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Refrigerators
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
The refrigerator compartment not cooling, freezer is ok so far
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
469d
Jun 03, 2010 | Gladiator 19 cu. ft. Chillerator Garage...
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Fridge is warm, freezer works.
Smilar problem, but the model is GTH15BBMFLWW
Jul 16, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Refrigerators Logo
169 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steven Clarke
Steven Clarke
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
