Question about Acer AL1916W 19" LCD Monitor
Color how can I get the color on my monitor to be lighter?
  • r_1y Jun 24, 2008
    Everytime I try to adjust the display through the LCD Pannel, it's always go back adjust automatically, these happen when our customer play the TANTRA Online Game, please help us....
    How can we change it mannually?? The game appears so dark.... can't change to lighter display
    Problem Solver:
  • 8 Answers
Just click on the menu then go to the fourth option [with 3 cirles] in that select the last user option nd decrese as per ur need... it will decrease the colour...
Posted on Sep 02, 2008
Subtle Two Toned Split Screen Color Difference.I think I hit some button by accident. Monitor is great but now I have a split screen where the left hand side of the screen has a lighter tint than the right...
Hi. I have got the same problem, and it was very easy to solve. Monitor was LG. The problem was not in the system, it was in the monitor. I just clicked the buttons on the monitor, it was on the wrong setting that divides monitor in two colors, so if it happens to you, try checking your monitor settings, mine was set to "demonstration", half was lighter than the other one, just set it to usual or user. Keep in mind the settings are on the monitor itself, not in the windows (buttons on the monitor itself) Good luck.
May 10, 2012 | LG 22" FLATRON LCD Monitor
Problem with color monitor BenQ G900W лblack tsvyan almost gone? and the predominant red hue! how to fix it
BenQ 19" monitor GENERIC pnP lcd
displays upper part (a 12 cm wide band) lighter than the down part which is normal
the cursor when in the lighter part becomes ghosty and very white
Oct 27, 2010 | BenQ G900W Monitor
Half e HPw1907 screen is of a lighter color as compared to e rest
It seems from your discription like your lcd back light my be failing, i suggest taking th tv back to where you bought it to see if they will repair it or give you a new one, it all depends on if it is still under warranty. If not it might be worth trying to get hold of a new back light of the internet and fitting it yourself though it can be quite hard and me back if you need further help.
Jan 27, 2010 | HP w1907 LCD Monitor
HI, I have a NEC monitor 1760nx, dark blotches on the screen
Listen, for what it is going to cost you to fix the unit, you are better off replacing it and having a new warranty to boot. Simply not cost effective to repair given the cost of a new monitor these days.
Mar 12, 2017 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
Color noise suddenly appeared on screen, blacks show blue noise lighter colors yellow noise
You may have a poor connection with your LVDS cable which connects from the internal main board to the screen. This will either need to bre-seated or replaced.
Sep 23, 2009 | Samsung SyncMaster 245BW Monitor
Screen colour not matching the printed pages
Unfortunately that's the age old problem of matching colors between computers and printers. Your printer is probably not the problem, that's why he couldn't fix it. Even though your monitor is set to default values it doesn't mean that your colors are correct as colors can vary from monitor to monitor and the color temperature is probably too high causing the colors to look lighter than the printout. The picture on the monitor may look good to you, but it's not set right for matching printer colors. Monitors use RGB (Red, Green & Blue colors) colors and printers use CYMK (Cyan, Yellow, Magenta & Black) colors and you have to make them get the results you want. You will have to do some tweaking of your monitor's settings to get it to match the printer output. Below are some links that will help explain things better and maybe help you adjust your monitor.;_ylt=AjWgmLYL.EGyC5z6hTuiEILty6IX;_ylv=3?qid=20090405191851AAl0xOq&show=7#profile-info-R3GCvDlKaa
Feb 28, 2009 | HP LaserJet 3600dn Printer
Dark colors
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
Oct 26, 2008 | LG Studioworks 700S 17" CRT Monitor
Dark display
dear mr faolib
the solution is to install a 250 ohm resistor between G1 and ground on the socket ,,,but you may change it more or less than 250 ohm . it well be lighter and you you can adjusted normally from controll panel
ghassan eid
Oct 20, 2008 | LG Studioworks 700S 17" CRT Monitor
Screen colors washed out
You can RESET the monitor setting externally by clicking adjustment menu button goto RESET press ok. If contrast and birghtness not set properly light will not be properly visible
Dec 10, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
