Question about IBM ThinkPad T20 2647 Notebook
Power switch problem
My computer does not switch on
    Scholar:
  • 139 Answers
To actually solve yr problem, you troubleshoot by trying the following:
* use a multimeter to test the power adapter if its working well. u can as well do this by using a flexible cable touching one end of the cable in the middle pin(+) of the power that is d dc area then the other part of the flex cable on the outside (-) it should spark which shows its working well.
* remove yr battery from the laptop n plug in direct ac to it then power on. if not on yet
*try to check the port where u plug in power to the laptop n see if its still firm to the board if yes
*meet a professional then
thank u
Posted on May 23, 2008
    Genius:
  • 2,785 Answers
Plz check your power supply unit
Posted on May 21, 2008
Gateway DX4822-01 power switch problems
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Main wires such as Power On LED, Power On switch, HarDDrive activity LED, and Reset switch; IF used.
Suggest KEEP track of where those wires go!
Make a drawing, and notes. I even use a magic marker, (Sharpee?), and make a notation of the Front Panel header pinout, on the floor of the computer case.
In this particular case it isn't known if the Power On switch is the problem, or the Power Supply.
Power On switch;
Power UNPLUGGED to computer, Anti-Static Precautions FOLLOWED; (Don't know? Post back in a Comment),
Remove the twisted pair of W/B and W/G wires, to the Power On switch pins, in the Front Panel header.
Plug power back into computer.
Use a small flat tipped screwdriver, and touch the two Power On switch pins. (Jewelers screwdriver works well for this application)
Power Supply comes on? Bad Power On switch.
Allow Windows to fully load, run for a few minutes; then turn the computer off normally.
Jump the two Power On switch pins again.
Power Supply comes on? You DEFINITELY have a bad Power On switch.
Power Supply does NOT come on?
We will go to a further diagnostic test then.
Awaiting results for first test, then we will go on.
Post back in a Comment.
Regards,
joecoolvette
[Also; is the computer dirty inside? ]
Feb 19, 2013 | Acer Computers & Internet
Can't turn on power to desktop
Simple power hack, to do this, kind of like hot wiring your computer.
Turn the power on at the wall, Flick the switch on the back of the computer (if there is one on the back) to the on position, make sure the cable is plugged in, and turn the power off at the wall, hold the power switch on the front and turn the power on at the wall.
This will cause the power to jump across the switch, causing the computer so sound a bit like a motorbike being started.
The power will come on it will turn over click and go off. After this turn the switch of at the back of the computer, and turn it back on, and the computer will boot up.
The first bit of this is just charging the capacitors in the power supply, the second bit is turning your computer on.
Oct 15, 2012 | Dell Computers & Internet
Computer has not power
If the power supply is bad replace it.
If the computer boots up for a second and then shuts down you can try the following method:
Remove the battery for a few minutes, put the battery back. Locate the connection to the power switch, turn computer on and then quickly disconnect the power switch
. If you have a battery with a power switch you can use that instead. Otherwise if this method solves your problem you will have to turn the computer on and off by plugging and unplugging it.
If you are going to get a new power supply, look for one that has a power switch on it.
Dec 14, 2010 | Acer Power FG (APFGUP5161) PC Desktop
Gateway mx6448 Notebook will not power on, Red LED flashes 4 times when power on button is pressed then nothing happens. It is the same with only the battery. LED will not flash if I have only the power...
There can be many things associated with no power to the computer.
  • The outlet into which the computer is plugged may be inoperative.
  • The surge protector you are using may be inoperative.
  • The power cable may be loose or damaged.
  • An internal device may be damaged.
  • The power supply may be inoperative.
Basic Troubleshooting Power to the Computer
There may not be a consistent flow of power to the computer.
  1. Verify that the outlet into which you are plugging the computer is operational.
  2. If you have the computer plugged into a surge protector, plug it directly into the outlet.
  3. Verify that the power cable is plugged securely into the back of the computer.
  4. If you have a monitor with a removable power cord, swap the power cords between the monitor and the computer.
Note: If you recently added a new hardware device prior to experiencing the no power issue, turn off the computer and remove the newly added hardware. If there is still no power, reseat all the other cards and cables in the computer to verify that all other devices are seated securely.
Resolving Power Supply Issues
  • External Device Conflicts
  • There may be an external device causing the computer not to turn on properly.
    1. Before continuing, verify your computer is turned off.
    2. After you have established that adequate electricity is going to your computer, verify that the voltage switch on the back of the power supply is set correctly. The small red switch is to be set to the 115-volt setting.
    3. Remove all external devices except the monitor and turn on the computer. If the fan on the back of the computer now spins, turn off the computer. Plug in the external devices one at a time and turn on the computer after each device is added.
    4. Note: If you removed all external components and the fan on the back of the computer does not spin, the problem is with something inside the computer.
  • Internal Device Conflicts
  • This helps determine if the issue is a damaged or badly seated component.
    1. Verify that the computer is turned off.
    2. Remove the case from the computer.
    3. Remove all the red, yellow, and black power connectors from each floppy disk drive, CD-ROM drive, and tape backup unit that is in the computer. The only devices connected to the power supply are your hard disk drive and motherboard.
    4. Turn on the computer and verify that the fan on the back of the computer spins. If it does not spin, turn off the computer.
    5. Remove the power connection from the hard disk drive and reconnect power to one floppy disk drive. Turn on the computer and verify that the fan on the back of the computer spins.
    6. Reseat the power connection from the power supply to the motherboard. Turn on the computer and verify that the fan on the back of the computer spins. If the power has been restored, turn off the computer and reconnect the power connections to the devices. Test the computer for power after reconnecting each device.
  • Power Switch
  • The power switch may not be functioning properly.
    1. You may need to open the case and readjust the power switch.
    2. Locate the control panel inside the computer and remove any screws holding it in place.
    3. Turn on the computer with the control panel removed by pressing the button on the control panel that corresponds to the power button. If the power supply fan spins and/or the computer turns on, put the control panel back in its place. Try to turn on the computer again.
  • Test Switch and Diagnostic LED
  • Note: Not all power supplies have a test switch and diagnostic LED.
    Certain power supplies have a test switch and LED to help better troubleshoot the device. The green LED is always on when the computer is powered on. If the computer is not receiving power please perform the diagnostic test below.
    3. Remove all of the red, yellow, and black power connectors from each floppy disk drive and ROM drive and the tape backup unit (TBU) that is in the computer. Remove all power connectors from the motherboard. The only device that needs to be connected to the power supply is the hard disk drive.
    4. Press and hold the test switch for five seconds on the power supply, and then verify that the green light on the power supply comes on.
    5. If the light comes on:
      1. The power supply is good and something that was plugged into the power supply is causing the computer to not turn on.
      2. Plug devices in one at a time, testing with the test switch between each device to determine what is causing the power issue.
      3. If all devices are plugged in and the light is working, the connections may have needed to be reseated, or it is possibly a power switch issue.
      4. Go to the power switch section of the power supply checklist for additional troubleshooting steps.
    6. If the light does not come on:
      1. Disconnect the power from the hard disk drive, and then plug in power to the CD-ROM drive and determine whether the light comes on.
      2. If it does, follow the preceding information - "If the light comes on."
      3. If the light still does not come on, contact Gateway Technical Support.
    7. Confirm that power from the power supply is connected to the motherboard. Remove all cards and cables from the motherboard, and press and hold the test switch for five seconds on the power supply and determine whether the green light-emitting diode (LED) comes on.
    8. If the LED comes on, put the devices back in one at a time, testing between each device to determine what is causing the issue.
Dec 02, 2010 | Gateway MX6448 Notebook
No power cannot turn on
Suggest you check the simple stuff first.
Not checking is akin to a car that won't start, and tearing apart the entire fuel system, only to find it was just out of gas.
1) Make sure the receptacle the surge protector is plugged into, has power. Surge protector Power On light should be lit.
2) Check THE receptacle in the surge protector, that the computer itself, is plugged into.
Have had a number of expense surge protectors, where just THAT receptacle was bad.
("Hmmm, surge protector Power On LED light is lit. Monitor, printer, sound system, and router plugged into the surge protector has power. Should be good to go.
NOT!
Plug a table lamp, or similar device into THAT receptacle.
Make SURE it has power)
Surge protector, and receptacle in surge protector checks out?
Bypass the Power On switch.
See if the problem is a $5 Power On switch, or the Power Supply.
(Generic ATX Power On switch that I have found fits many computers,
http://www.directron.com/atxswitch.html
{The Power On switch, is located inside the plastic Power On button assembly}
This is information about computer Power Supply's,
http://en.wikipedia.org/wiki/Computer_power_supply
This is a basic example of an SMPS, (Photo at upper right. You can click on the photo to enlarge), and info about.
(Switched-Mode Power Supply. The main type of power supply used in personal computers),
http://en.wikipedia.org/wiki/Switched-mode_power_supply
By bypassing the Power On switch, you will be able to determine if the problem is the switch, or Power Supply.
Bypassing the Power On switch turns the Power Supply on?
Bypassing the Power On switch does Not turn the Power Supply on?
Bad Power Supply.
A jumper wire is used on the 20, or 24-pin ATX main power cable.
The jumper wire goes to the Soft Power On, (PS_ON. Green in color), to ANY Ground wire.
(ALL Black wires are Ground wires)
A MOMENTARY contact is used.
(Example of a 24-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24 )
In order to guide you in this procedure, I need to know the computer manufacturer name, and Model Number.
On a desktop computer this will be located on the Back of the computer tower, (Next to the Windows product key), or up on the side of the tower.
Some models have it where there is a door you open in the front, and the product number, or model number is located there.
Aug 07, 2010 | HP Computers & Internet
I have a problem with my pc it will not boot up it starts to boot then just turns off I cant get and diag done to troblem shoot the problem PC specs Win XP sp3 3gb ram DDR2 Celeron D...
now, this sort of shut down is difficult to diagnose on remote, i would suggest downloading your motherboard manual beforehand. before you do anything, i would suggest read in manual where is reset pin and how to reset bios to original state, but do not do that yet, it will lost all your mods settings and return m/b - bios to original state. there are several possible causes of that fault.
1. faulty memory stick
2. thermal or fault on power supply
3. thermal or fault on motherboard
4. corrupted bios
we will start with easiest to check re 1.
a. switch off your computer,
b. remove power cable from power supply,
c. remove side wall,
d. remove memory sticks and replace them with known working ones from another computer
e. reconnect power supply and switch computer on, if computer works correctly, you solved your problem and need to replace memory sticks
power supply is not much more difficult re2.
c. remove power supply cables from motherboard and all accessories, do not remove power supplly from it's craddle yet
d. connect cables from new power supply to your motherboard and processor fan, connect them to your hdd and cdrom,
e. connect power cable to new power supply and start your computer, if computer run correctly, switch it off, remove old power supply and replace with new one
most tiddly bit... when you arrive here that meant that previous two did not solved your problem, re 3:
c. disconnect all cables from your m/b
d. connect power supply to m/b and processor fan
e. connect ps2 keyboard
f. connect monitor if "all in one" m/b, video card and then monitor in any other case
g. insert power cable to power supply
h. switch on your computer
i. acess bios (that is usually done by tapping "delete" key, find in your manual) if possible, if not then:
i1. switch off power supply
i2. remove power cable from power supply
i3. re-set bios (you need to locate reset pins/switch/button on you motherboard in manual)
i3. reconnect power supply cable \
i4. switch on the computer
j. acess bios and set your thermal to 75centigrade or 80 centigrade and 5min
k. close bios saving changes
l. re-boot your computer and leave it for 10min, if computer still run, that will indicate your problem lies elsewhere.
checking auxiliaries:
c. connect cd-rom
d. reinstall power cable and re-start your computer
e. allow 10min run and check if computer is still running
switch off. remove cable and connect your hard disk drive, run or switched off? if off, you need to check your hdd...
any other auxiliaries need to be connected again in steps and if finaly you find one which terminated boot up, this meant that this particular element is responcible and need replacing. you need as well consider that your power supply maybe perfect on the bench, but will be too small for load required adn simple upgrade to more powerfull mother board can solve the problem.
hope that half book on problem solving solve yours :-)
Jul 30, 2010 | Computers & Internet
Power button not working. computer won't turn on. I got a light on, on the mother board but computer won't turn on
This is usually caused by either a faulty power supply or a dirty switch. You can find out if it's the switch by pulling the wires off the motherboard where the power switch plugs in, and with the power supply plugged in, carefully short across the two pins. If the computer doesn't start, that rules out the power switch. The other likely culprit is the power supply. If you can get ahold of a different power supply, try hooking it up and power up the computer. If that daesn't work, chances are that your motherboard is shot. Good luck.
Apr 13, 2010 | Computers & Internet
My asus a7n8x motherboard based computer won't switch on - I press the power up button - and... nothing!
First try switching the power cable that goes from the power supply to the wall switch. You would be surprised at how many times that is the case. If you know for sure that power supply cable is good, You possibly have a bad power supply. You can purchase these for about $40.00 at most of your computer stores. But before spending your money on the power supply, make sure that the switch that turns on the computer is not bad. a- check power supply cable b-check computer on/off switch c-check power supply. Good Luck
Jul 14, 2009 | Computers & Internet
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Push switch, no power.
It can be the power supply. Does the power supply fan work when you push the power switch ?
Jul 22, 2007 | HP Pavilion xl756 (P1358A#888) PC Desktop
IBM ThinkPad T20 2647 Notebook Logo
27 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
