Question about Tomtom One XL GPS Receiver
Tom Tom One XL
My TomTom One XL has started to switch itself off for no apparent reason. Switch it on and it carries on with the same journey. five times in a one hour journey today!
  • sider1 May 21, 2008
    turns on shutsoff
  • Anonymous May 28, 2008
    Same problem...Reset it and it happened again.
HAD TO DO A SOFTWARE UPDATE AND CLEAR FLASH UTILITY FROM TOMTOM TO FIX THIS MYSELF. CAN DO BOTH FROM TOMTOM HOME AND/OR TECH SUPPORT. BE PREPARED FOR A WAIT. TOOK 1-1/2 HOURS TO GET TO THIS FIX.
GOOD LUCK!
Posted on May 21, 2008
Device comes on but shows flashing X and nothing else.
The flashing X is usually asscosiated with a corrupt memory card or a pirate copy of a map.
if it is the later then restore the device from a backup to go back to your original map.
If it is a corrupt card then carry on reading below
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now need to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your SD card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the SD card
It should now work
Bob
Aug 05, 2010 | Tomtom ONE XL GPS
I tried to update my tom tom now when i switch it
reinstall the software.
if that doesn't work you can copy all the files out of the tomtom into a new folder then delete all the files and update again.
and if that still doesn't phone tomtom support
Apr 23, 2010 | Tomtom ONE XL GPS
Display reads problem with map
You now ned to select your tom tom which will also show as a drive.
Then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL 330 GPS Receiver
How do I update my tom tom xl once it is plugged into my computer?
you need to download tomtom home from the tomtom site. it will do it almost automatically.
just choose your operating system, then after you run it on your computer, just follow the on screen instructions.
Oct 14, 2009 | Tomtom One XL GPS Receiver
My gps tom tom turns itself on waht could be
If you search for "TomTom turns itself on", you will find that there appears to be a problem which TomTom will not acknowledge. Mine always turns itself back on exactly (to the minute) one week after being switched off and runs the battery down. Tomtom have got me to reformat and had it back for repair but the problem remains
Oct 10, 2009 | Tomtom ONE GPS Receiver
Red x on Tom Tom
This is TomToms fix, apparently something went wrong with the software, my advice would be to make a back up of the device using the TomTom home software.
This issue can come from disconnecting the device while it is attached to the computer and software while it is busy, always make sure you use the eject device in the TomTom home software if you are connected to the PC.
http://www.tomtom.com/support/solution.php?GID=1&PID=2029&SID=0&CID=152&Language=4&FID=2053
Aug 11, 2009 | Tomtom XL 330 Car GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Tomtom one xl wont switch on properly
How do I change the batteries in my Tom Tom One.
May 18, 2009 | Tomtom One XL GPS Receiver
Password issues with tom tom one xl
I got this similar password problem with Tomtom One XL. I just solve this problem step by step under the following ways.
1. Connect One XL to TomTom Home in your computer using USB cable and switch on ONE XL. (Click YES to connect each other)
2a. Click "Manage my ONE XL"
2b. Click "Items on device" tag.
3. Now you can see all of the data in your device and click "Applications".
4. Click inside the check box and click "Copy items to computer".
(This step is back up for just incase)
5. After Backing up your applications, then Click "Applications" check box and click "Remove from device".
6. After removing applications, unplug from computer and switch off ONE XL.
7. Connect ONE XL and computer again and switch on your ONE XL.
8. TOMTOM Home will search your applications in your device. Finally it will automatically download and installed the new applications. (There will be 4 times installation and the device will restart itself. At this step, you need to touch "Yes" on your device to connect the device and computer.)
9. After installation completed, your device looks like newly come out from the factory.
10. Set up Language, Time, and so on and ready to use.
Enjoy it
Austin Tan
Feb 10, 2009 | Tomtom One XL GPS Receiver
Tomtom xl 330.s wont speek street names
Yes Nickarino is right.
When I switched on my new tom tom it gave me that option to speak street names and it vanished after selected a different voice. I checked all manuals and web references in Tom Tom - none of them list it.
Like Nick said - what you need to do is swtich the voice type to SAMANTHA and it will show the option "Read Street Names Loudly". I jumped on it and said yes ..!!!
Thanks Nick !!
Dec 26, 2008 | Tomtom XL 330S GPS Receiver
Tomtom One XL GPS Receiver Logo
236 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
