Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Mobile connector for steam tube...
The steam wand broke off from my espresso machine, or rather the little plastic piece where you can screw it on and off (which I hardly ever did). As far as I can tell from the diagram the parts that I would need to repair it are:
96 228660204 Connector for steam tube and/or
97 228660304 Mobile connector for steam tube
Does anyone know where they might be available for ordering?
Thank you so much!
Anna
Not sure if you got the part. I called Saeco USA and they sent me the little swivel joint which supposedly is a strong plastic component. check with them
Posted on Aug 24, 2008
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
My machine will not froth milk
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Plastic on steamarm blew off
Those pieces (2 of them) are suppose to come off. The outer sleeve turns 1/8th of turn clockwise looking down on it and then can be slid down. The inner slides off and has a flat spot on the back to line up with the steam wand, it's held in place by an o ring. All can be ordered through Delonghi.
They are designed to be removable so they can be cleaned after each use.
Before replacing any other parts, try descaling your machine. Build up will cause heating and steaming issues.
Aug 23, 2009 | DeLonghi EAM3400 Espresso Machine
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
Lost a piece of the black plastic steaming wand
Check with WholeLatteLove, yes I know the only have gaggia parts, its the same thing.
May 07, 2009 | Saeco VIA Venezia
Plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
Feb 27, 2009 | Gaggia Carezza Espresso Machine
Nozzle won't stay on steam tube
There should be two rubber pieces inside the threaded collar & cap that help produce a pressure fit onto the wand itself. There is a total of five plastic pieces on my steam wand excluding the wand itself on my Via Venezia by Saeco I purchased a year ago. Sounds to me like you lost one of you rubber gromets! Just my thoughts!
Dec 20, 2008 | Saeco VIA Venezia
Water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Dec 07, 2008 | Rancilio Silvia Espresso Machine
Saeco Gran Crema Espresso does not pump water
The machine needs to be primes.
Please trie and release hot water though the steam nossle.
Do like this
Open the steamer and then trie and make a cup of coffe. this will make the hot water come out thought the steamer instead of the coffe outlet.
Why you should do this is becuse the machine has it alot more easier to prime it self though the steamer then the coffe outlet.
Jun 21, 2008 | Saeco Gran Crema Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
107 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
rob j
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
