Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Clicking noise My gas valve continually clicks when the heater is running. I fires up and runs well but just keeps clicking. Any ideas?
  • Clifflovette May 23, 2008
    i have the same clicking problem. It even sounds like their a tiny gas explosions in the heater.
  • meetch12 May 23, 2008
    I replaced the pressure switch and seems to be okay now....but before you do that make sure the filter is backwashed.
Please let me know if you get a solution for this--mine has been doing this as well (404)-583-4095 Cliff in Atlanta
Posted on May 23, 2008
Rinnai r85 exterior propane tankless water heater makes knocking/clicking noise. seems it tries to start with clicking noise then no fire in burners then cycles again. no error message. have two rinnia...
on start up the clicking noise is normal as well as knocking noise ....one important item with fan , if the fan was removed cleaned and then reinstalled with power to unit could have ruined the fan and it will have to be replaced..... Cant tell you why is wasn't firing before with no codes...other than flow sensor not working( most likey stopped with sand fragments or trash) the flow sensor detects hot water demand and ignites heater and if clogged it will not light up but doesn't give error code and the water running through hot side will be cold..... flow sensor is a turbine that detects water movement and lets heater light..... may want to get serviceman to check this out and clean turbine.... hope this helps...
Mar 27, 2014 | Heating & Cooling
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
My sterling radiator is not firing off and making clicking noise. i believe i need to hit a reset button but cant seem to find any such button.
I BELIVE THE CLICKING NOISE IS THE ELECTRIC IGNITOR,NO FUEL IS COMING OUT SO IT WONT IGNITE, CHECK THE GAS CONTROL VALVE TH EY SHOULD HAVE 24 VOLTS GOING TO IT IF IT DOES, THEN THE VALVE IS BAD, GOOD LUCK
Jan 21, 2010 | Heating & Cooling
Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Dec 13, 2009 | Dayton Heating & Cooling
My laars swimming pool pilot light keeps going out and it makes a clicking noise when it fires up and the pilot light goes out? it has been going on and off alot recently but can work for weeks on end then...
check power pile conections on gas control valve.it is the 2 wires that come from pilot asembly.if they are loose or have rust or oxidation this can affect pilot and cause intermittent outage. let me know
Jul 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Dyna Glo forced air propane heater
...found out that this is a continuous ignition heater so the igniter is always on.
Sep 22, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
111 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
