Back to:
Tags:
Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Toshiba TV Combo MW24FP1, DVD player doesn't work...
posted by misti99 on May 21, 2008
Generic problem for all DVD Players Toshiba MW24FP1 TV/VCR/DVD combo... plays some posted by misti99 on May 20, 2008 Report abuse
plays some DVD's but not all... after putting in
the DVD, it shows 'Reading disc', then get an error
message..'incorrect disc'..... it is 2 years old and
hasn't been used very much.... called the DVD movie company, they said some of these combo's have the same problem.... Is there any recalls, anything we can do to solve the problem, or as a last resort, can another DVD player be hooked up to this combo....is that possible... HELP... Thanks,
Comment by misti99, posted on May 21, 2008
Dan...thanks, I kinda figured it was possibly dust....no I don't feel comfortable since the DVD player is at the bottom of the TV... so what cover are you referring to ??? Does the front of the DVD player come off ??? Could you explain in detail....
Would appreciate any help since we don't know where to take it to get it checked out and what it would cost....
Thanks again.... Sandi
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
Abrsvcs
Rank:Guru Guru
Rating: 86%, 797 votes
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
TV Combos
my tv comes on the only thing that it will do is samsung...
I tried to set the timer but it won't go on
The TV will not turn on either by the remote control or by...
One day I moved the TV to a different part of the house...
can still see the picture but is this a setting problem,...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
