Question about Xerox DocuColor 3535 Copier
Erorr 010-348 changed fuser still no good
  • 4 more comments
  • tony1234567 May 21, 2008
  • HazeGrey May 23, 2008
    I have the same problem. Error code 010-348 keeps comming up when I start the copier. I tried to change the fuser but that did not help. How do I reset the copier? Thanks.
  • kreshniksmaj Jan 06, 2009
    I have a problem whith this code 010-348... what can i do...???
  • wells00 Apr 18, 2009
    devo risolvere il guasto 010-348 su xerox docucolor 3535. qualcuno mi può aiutare?
    they have a DocuColor 3535, during a normal working machinery has gone into error (010-348). Changing fuser error remains, perhaps I can describe, if any, the procedure to start the car?
    Excuse my English is very poor.
    Thanks
  • wells00 Apr 20, 2009
    Thanks
    My email for private contact: xabraras@hotmail.it
Go to lokation 131 end 744-003 cheng 1-0
in diagnostik monde procedure is pres 0 wait five sekand end pres start buton
6789 confirm pres accses buton go tu Diagnostik nvw red end wrait, pres nuber 744-003 new volume
pres 0 end start
qaoo
with respekt DrinCopy Kosovo -Albania
Posted on Nov 30, 2008
008-164
008-900
Posted on Aug 08, 2008
    Problem Solver:
They have a DocuColor 3535, during a normal working machinery has gone into error (010-348). Changing fuser error remains, perhaps I can describe, if any, the procedure to start the car?
Thanks
My email for private contact: 42961@email.it
Posted on Jan 12, 2010
    President:
  • 2,072 Answers
Well,, then you may have poor contact, but other than connectors the other items in the circuit are the Main Processor, MCU and the AC drive board. Here is the documentation..
You probably have to reset a NVM location, I have to go to a meeting, after I am out I will send you the procedure.
Can I E-mail it to you? Can you provide me an E-mail address please.
There is one location that has to be reset if the fault occured 3 times or more.
With the new fuser and resetting that I am sure it will work fine.
Posted on May 21, 2008
Canon ir 2202 erorr cod e002-0000
see if this link helps
http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
Mar 15, 2016 | Canon Office Equipment & Supplies
Canon ir2318l
Change the fixing unit. That erorr indicated the fixim filim erorr . Or dc control pcb
Dec 10, 2013 | Office Equipment & Supplies
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
on the panel again press 163
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
Oct 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
I found in canon ir 2018 erorr E 007 what this mean and what the solution ?
it is mean the fixing film was broken/torn.
you must replace a new.
be careful when you replace it.
May 17, 2011 | Canon iR 2016i Black and White Copier
It gives a code sc 542
The error code is related to the fuser area.
Likely to be a low fuser temp issue.
Need to verify good or bad heat lamps.
1) Check each lamp in fuser.
(lamp is good if you get continuity)
(lamp is bad if open)
2) Check the thermostat. (thermal control device)
(triggers if unit gets too hot)
3) Also check thermistor (monitors temp of fuser)
(2) total (middle and rear)
If heat lamp is good:
Your best bet is to change all three items. (Temp fix)
Fuser thermostat - thermal control device
Fuser thermistor (middle front) - thermal control device
Fuser thermistor (rear) - thermal control device
These items wear out. Change at the same time.
Fuser needs to be rebuilt or replaced.
Oct 19, 2010 | Ricoh Aficio AP610N Laser Printer
Erorr code 10-327
reset ur fuser module
press 0 and hold for 5 second than press start button
enter passcode 6789 and press confirm
press machine status and press tools on touch screen
press maintenance and diagnostics
nvm read /write
type chainlink 744-220
enter new value 0 and save
after close the log
restart ur machine
Sep 25, 2010 | Xerox CopyCentre C128 Black and White...
EPSON C1100 E 510 EROR
E510 idicate the ROS motor faulty... PWBA MCU could not receive signals output from SOS Sensor in ROS within the specified time.
Possible cause ROS assy, PWB MCU, Harness PWB, or LVPS..
but before you change any.. make sure all your cover are close properly..normally the fuser cover interlock switch can cause this error as well.. check the switch at the right side of the fuser cover...make sure it's not deform .
May 21, 2010 | Epson Aculaser C1100 Printer
Kode erorr e0000-000
This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
May 15, 2010 | Canon imageRUNNER 5000 Copier
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Apr 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Fault code sc542 appears on screen
(Check for wear and tear)
Inexpensive repair for the temp fix.
The whole Fuser cost can brake the bank.
I buy parts from precisionroller .com (you can preview the parts)
Franklin
baselinerepair .com
Apr 20, 2008 | Office Equipment & Supplies
1,212 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
