Question about Toshiba Computers & Internet
I have no power on my Toshiba Satellite U300-11v. I have checked the fuse in the external cable supply but the Laptop is dead - the external power supply indicator does not even illuminate.
  • Rob72 May 21, 2008
    Thanks myob247 for quick response - have done all you suggest - no luck.
    Dude you rock !!! Not only did that work but I'm using the laptop to thank you - all seems OK., Thanks so much buddy - very much appreciated,
    Guru:
  • 1,342 Answers
It may be the power supply. Try a different one. Try a different power outlet.
Posted on May 21, 2008
  • Georgia B
    Georgia B May 21, 2008
    Try removing all power. Power supply and battery. Hold in the power button for up to 1 minute to discharge the laptop. If it still doesn't boot it may be the ac plug on the laptop.
  • Georgia B
    Glad to hear it worked.
    Thank you for voting.
Toshiba Laptop Dead no bios
Most of laptops batteries have electronics inside them wich test and transmit info about the battery itself. Maybe the fail is there and not in the laptop. Try with another battery befor dumping it.
Dec 01, 2012 | Toshiba Satellite A305-S6859 Notebook
I can barely see the screen, its very dark. Its a toshiba satellite m115 s1061
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 05, 2010 | Toshiba Satellite M115-S1061 Notebook
Keyboard frozen, cannot unfreeze
First try pluggin in an external keyboard, if that works and your internal one still doesn't work after unplugging the external one, you may have a problem with the insides (small plugs and cables) other wise if the external one doesn't work, it could be many things, ie cmos, other cables, other plugs, entire USB system, power supply (internal), too much to list and troubleshoot here.
Jun 25, 2010 | Toshiba Satellite L505ES5018 Laptop
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Hi, I have a Toshiba Satellite a205-s5825. Do you know if there is a fuse on the motherboard somewhere. I looked and looked but can not find a thing. I have no power, lights, nothing. It's a dead no power...
There are no fuses on a laptop. I'm afraid you most likely have a dead mainboard. The good news is Ebay has tons of them or lots of parts sellers that have them. I'll include a link below for the service manual that would help you in this endeavor...
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
service manual is here...
http://tim.id.au/laptops/toshiba/satellite%20a200.pdf
Sep 27, 2009 | Computers & Internet
Toshiba laptop a105 dead screen
it looks like the power supply for the light on the lcd screen os disconnected.If you can go deper to dissassemble the laptop you will find the connectors(like small plugs).check all the wires connecting to the screen.
Oct 04, 2008 | Toshiba Satellite A105 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
