Back to:
Tags:
Panasonic FP-7750 Black and White Copier
Command shows that door is open
posted by SalimFatema on May 21, 2008
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 22, 2008
Not Rated (0)
Cogz
Rank:Guru Guru
Rating: 85%, 176 votes
What door or cover is the display showing that it is opened? I would look to see if there is any thing that looks broken on any one of the doors. They have on them little tabs that act as a inter lock device to close a switch. Also, look to see if all the doors close easy without forceing it. try to cheat the doors with a pen or a piece of paper to see which door is not closing. Most of the time a switch or sensor is behind a **** on the inside covers. I would start with retracing the last time you removed a paper jam.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Command shows that door is open:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Copiers
My copier was working properly, when one day it just...
Copiers
I have a Risograph RZ220 with the code d--13 --9. The...
Copiers
how to reset the copier thanks chris
Copiers
hello Bubba how can i found cable for aficio 1085 to pc
error code internal 10
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
