Question about HP Pavilion zd8000 Notebook
ZD8000 not turning on
Shut my computer down when i went on holiday, got back started it up and now it just won't turn on, when you press the power button all the leds flashes for a moment, plus the fan just moves and than stops.
  • 50 Answers
Sounds like the motherboard has gone bad. You may try taking the ram out one at a time but more than likely it is the mb.
Posted on May 21, 2008
My computer wont start on after bios update failure
And nothing will happen. Do not PERFORM BIOS UPDATE unless strictly necessary. Do not perform BIOS UPDATE without CHARGER plugged in and be sure you have enough power for 10 minutes. NOW... If you are lucky, in service they will be able to REWRITE your BIOS. Check HP website for service in your area. If not, your motherboard will have to be replaced. Good luck. Keep us informed of the results.
If computer SHUT DOWN while reading BIOS FILES you might have a little chance to repair it. Unplug battery. Charger must not be connected. Press POWER for 30-40 seconds. Plug back battery. Press power. And pray before this.
IF this will not repair it... the two options described before will...
Oct 30, 2012 | HP Pavilion zd8000 Laptop MOTHERBOARD...
Computer will not start after going into sleep mode
Shut pc down unplug power supply press and hold power button for 20 seconds to remove all remaning power.open case clean any dust find ram sticks remove them make sure there clean and re seat them back into there slots.your monitor could be the cause also unhook it while pc is unplugged. now put it all back together and turn it on..if it doesnt shut it down un hook monitor and fire up pc see if the pc boots by watching the lights.if so bad monitor does light turn blue on monitor when power on.
Mar 16, 2012 | Computers & Internet
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
Apple 20 in Imac G5 turn on for about 40 second and shut it down itself .. please help
Sounds like you need to reset your SMU and NVRAM:
To reset your SMU:
  1. Turn off the computer by choosing Shut Down from the Apple menu, or by holding the power button until the computer turns off.
  2. Unplug all cables from the computer, including the power cord.
  3. Wait 10 seconds.
  4. Plug in the power cord while simultaneously pressing and holding the power button on the back of the computer.
  5. Let go of the power button.
  6. Press the power button once more to start up your iMac.
To reset your NVRAM:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
If those don't resolve the issue, your computer will probably need service. Good luck!
Oct 10, 2010 | Apple iMac G5 Desktop
Laptop won't turn on, no lights - nothing!
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 26, 2009 | HP Pavilion zd8000 Notebook
My ZD8000 Restarts automatically When I Shut It Down
This sounds like a hardware fault with the motherboard. I would suggest you resseting your BIOS to default settings. Do you know how to do that? Please advise...
Mar 09, 2009 | HP Pavilion zd8000 Notebook
Desktop Will Not Turn On
shut the tower off or unplug it form the back for a few minutes
plug in back in and then try to turn it on
you may have a power supply failure
let me know what happens
Jan 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Power turns on and off.
Try the steps listed below :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power
If the issue persists, try these steps to reset the BIOS to its defaults :
Start or restart the Notebook and start tapping the F10 Key which will take you to the BIOS setup window.
In this, press the F10 Key again to set the settings to its default and exit the BIOS setup screen.
If the issue still persists, make sure that the Power adapter of the notebook is correctly pluged into the Notebook.
Hope this helps...
Aug 25, 2008 | HP Pavilion zd8000 Notebook
Hp pc wont power on
make sure that the switch on the power supply is set on (the- side)
remove power cord, turn supply off then on and plug it back up and try it again. Power supply could be bad.
Jun 01, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
