Question about GE JGSP23 Gas Kitchen Range
GE Profile JGSP23 - Broiler does not work
All functions work properly except for the broiler. The manual does not address this issue.
Please advise.
Thank You.
  • wrl2 Feb 12, 2009
    broiler will not light igniter glows but will not flame
    Scholar:
  • 111 Answers
Sounds like an open (burned out) broil glow bar
Posted on Dec 16, 2008
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
The oven won't heat up the broiler works
More than likely, you have a bad igniter. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely NOT a control board issue, either.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. If the model number is correct, the part number for a replacement igniter is 330688.
NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
If you have any questions please post back and let me know. I hope this helps you.
Sep 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Sep 30, 2009 | GE JGBP28 Gas Kitchen Range
GE Profile Stove, stove top works but the oven will not heat up.
You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
Mar 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
No oven baking function
You need to replace the oven ignitor. The ignitor has to draw enough current to open the gas valve. Your ignitor is either broke or not working properly, so the ignitor will not lite the oven.
Jan 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile
let me understand, you p[lug in you oven and the broiler will automaticalle start??? not allowing you to cancel???? if that s the case unplug and remove the back panel from tyhe range, sound sas if the wire leading to the broil ignitor has shorted itself against the cabinet of the range itself, look for whiter braided wires at broiler hieght, chances arte they are hitting against hte cabinet right near the vent area.
May 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGSP23 Gas Kitchen Range Logo
109 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
