Hp Pavillion laptop. Powers up intermittantly. we purchased 2 of these for my sons one of which was repaired FOC (motherboard replaced) as a goodwill gesture as it was only 1 month out of warranty. Now the other one has the same fault.Seems its a common problem with HP Laptops but just wondered if you may be able to help with an alternitive solution to this very expensive repair? (around £300.00)
Hi Pinky01,
thanks for the response to my problem. I have contacted HP but they are not interested because the laptops are no longer warranted. We have had a response from the retailer and they will come and take a look at it but are making no promises but fingers crossed they may do a foc repair.
thanks again!
Posted on May 29, 2008
    Champion:
    Scholar:
  • 209 Answers
I think HP should do the repair for free. Since you've had the problem previously, it is not like you want a repair for the first time. Let them know what happened.
Posted on May 28, 2008
How to get a replacement for a HP Pavilion DV6 motherboard??
You will want to contact HP support directly to order the necessary part. The serial number of the machine in question will allow them to locate the correct part for you and set up a purchase and ship unless they prohibit non-HP repairs.
Mar 28, 2014 | Computers & Internet
Hi I have a HP pavillion DV6 iv'e had it for about 2 years and it wont turn on. I had it on once about 2 months ago after i researched a solotuion to the problem but after i turned it off again it wouldnt...
Hardware failure: the chipset of the motherboard has overheated and failed. You will need to take it to a repair shop, you will probably gonna have to replace the motherboard.
Feb 14, 2011 | HP Pavilion dv6000z Notebook
Is there a problem with the motherboard of your laptops ? i have a hp pavillion dv9500, purchased on dec 23 2007 s/n cnf7369232 and used approx 6 hr/ wk. that had the motherboard die last week, in my...
The HP Pavilion DV's have a common problem with their motherboard which relates mainly to the overheating of the video processor to a degree that its connections (solder points) with the motherboard melts by usage, causing loose connection & hence failure of the motherboard. This is a common problem well-known by laptop repair technicians for this family of HP Pavilions.
Oct 25, 2010 | HP Computers & Internet
HP Pavillion dv9000. Intermittent stops. Cannot restart, but will do so after many hours. Screen turns blue with band of torn blue that looks like shutters. System carries out repair check - once worked...
Try booting your computer in safe mode... when your machine starts press F8 and go to Windows. Run for a couple of hours and see if this problem happens.
If you have system restore running, restore back to a point when you didnt have the problem
May 17, 2010 | HP Pavilion dv9000z Notebook
Hp pavillion dv6 laptop no power
1. Check the adapter
2. Check the processor
3. Check the motherboard if defective replace new one.
Note: You need to know the right spare part number of your motherboard e.i 443776-001. Here's a sample video
May 04, 2010 | HP Pavilion DV6500Z Notebook
HP Pavillion ZD7010CA
it sounds like a bad motherboard or a bad power supply, try another power supply if you have access to one. if that doesnt cure it. let me know
Dec 09, 2009 | HP (344877-001) Motherboard
HP Pavillion entertainment dv6000 - Power goes
it is problem your laptop ram is rough position or demage change it then your laptop is active
Jul 17, 2009 | Computers & Internet
HP PAVILLION DV9500
HP will not cover the repair if guaranty is expired.
Video card on your laptop is integrated on motherboard, and the repairman must replace the whole motherboard to fix it.
I quote : "Only half the screen works the rest is justa grey colouring." that is more likely a problem with the ribbon cable, connecting LCD, or with LCD screen itself, in some case , as said by the repairman , it can be the video card.
if the repairman did not open and inspected the laptop LCD display , connector and cables, then the problem it is probably the ribbon cable or the LCD panel.
The technician mentioned the motherboard, because that is the most expensive repair service, so that he can cover his back.
Ask a quote to a different technician, see if this can give you different quotes for all possible faults.
The possibilities are:
1 Replace ribbon cable
2 Replace LCD display
3 Replace motherboard.
Oct 14, 2008 | HP Pavillion dv9740us Notebook
Hp pavillion laptop dv9000 power on problem
I thing problem in heatsink use heatsink paste.
Oct 02, 2008 | Intel Motherboard
Motherboard and processor failure
Dear Sir,
I would like to ask you if you have purchased an Extended Service Plan cause your laptop has a warranty of 1yr from the day of purchase.... so you need to contact HP and purchase a new Processor and Motherboard.... After that you can purchase 1yr Phone Support and 1 Hardware Support, If you have any problems with the system after that HP will replace the parts for you FOC cause you have the Hardware Support and incase if you are going to buy a new Notebook, plz go ahead and purchase 3 yrs Extended Warranty cause at any point of time if you have a problem HPwill be more than happy to send you parts in replacement for Faulty parts on your notebook
Apr 21, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
