Question about Kenmore 96213 Electric Kitchen Range
Kenmore E2 F3
I have read that you posted F3 means the heat sensor is gone. THANK YOU for that advice. but ours also flashes E2 before that. And the oven light would not turn off. We have unplugged it until we can get the part.
Also how do you find the model #, we bought this house a month ago and I can't see a model number on the unit.
Do you have any additional advice? THANK YOU
  • Anonymous Dec 16, 2008
    E2 F3 showed up and my cookies burned. What do these codes mean?
  • fultonbrewer Feb 20, 2009
    I set the oven to bake at 400, the E2-F3- appears. when this happens the lower element does not come on, however the upper element energises and will burn whatever you put in the oven.
  • 15,935 Answers
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
Kenmore gas oven says E2 F3
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 16, 2011 | Ovens
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
Top burner over heated and burned our food then E2 F3 fault showed up on keypad. Burns the outside of the food but does not cook the inside. The oven was on bake not broil. Model GY396LXPS00
Hi.
E2 F3 means Oven temperature is too high (Cook mode).
The first part to be tested is the temp sensor. The sensor is located inside oven cavity and it is tested using a multimeter set on Ohms to read impedance at sensor contacts.At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, check for a short to in element wiring (element stays always on). If element and sensor are OK replace the control.
Regards.
Ginko
Jun 10, 2011 | Whirlpool GY396 Electric Kitchen Range
I have an e2 f3 error and the broioler comes on full blast when it's plugged in
Hello & Welcome to FixYa
F3-E2 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Hello my oven will not turn off and it gives me an error of E2 F3
F3
- E0 Oven temperature sensor (RTD) opened
(upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode)
Dec 11, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
Don't know the model number. What does F-3 mean when it flashes when I try to turn on the oven temperture
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
What does F-3 mean when it flashes on my oven. Trying to turn on the oven for use
Hi
Thanks for using FixYa. Error F3 in your Kenmore range/oven indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 06, 2010 | Kenmore Kitchen Ranges
F3 error (sensor replaced) kenmore stove Oven reaches proper temp then about 15 minutes after starting beeper goes off and error code f3 appears
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then check the wire harness connecting the control & sensor (as you have already replaced the sensor) however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 05, 2010 | Kenmore Kitchen Ranges
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
Kenmore 96213 Electric Kitchen Range Logo
338 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
