Question about Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver
Acquiring signal I have 2 sportsters and am experiencing the same problems.  Aquiring signal.  I live in Chicago and this problem seems to be across the country.  Can someone in the legal community look into a class action lawsuit?  Please advise I am at my wits end.  dan
  • 1 more comment
  • tjrollo Aug 15, 2008
    no signal for about 40 minutes then came back with very spoty reception
  • Anonymous Aug 30, 2008
    Same problem as everyone else....display just reads acquiring signal, and no sound. However, during extended travel, signal is acquired after an hour or so into trip.l
  • jaycooper77 Nov 14, 2008
    Don't know what the problem is but radio always says acquiring signal. Nothing has changed since it worked until it gave me this message, except for time. checked wired and connections--all good. My radio works in the home docking unit but not car, so I know radio is ok. Help
Put it in the freezer for 20 minutes!
Posted on Aug 13, 2008
My wife replaced the car kit.
The sportster itself was fine, what fixed the problem was replacing the cradle.
Now the second one has taken a dump.
Posted on Jul 14, 2008
My sportster 5 satellite radio is not getting signal
Is it "Aquiring Signal" or "Antenna Not Detected"? It could be the antenna, the dock, or the radio itself. For whatever reason, the Sportster 5 seems more fragile in the dock connections. TSS Radio has a repair guy who can fix this issue. You can reach him via email at sales@tss-radio.com
Jun 15, 2012 | Sirius Sportster 5 Satellite Radio...
The dispaley states "aquiring antenna" but never finds it,can this be fixed?
Yes. However, it depends on what is causing the acquiring signal message. It could be that you just have to replace the dock or antenna. But it could also mean the unit is going bad, in which case it would need to be repaired. www.tss-radio.com has a repair guy, though with that unit being discontinued for as long as it has, he may not have parts. You may have to search around for a replacement on amazon or ebay.
Jun 01, 2012 | Sirius Satellite Radio Sirius Sportster...
GPS 40 will not finish aquiring signal
make sure the gps have a full view of the sky. leave it in aquiring mode and let it sit there. My Emap took up to 35 mins once to reaquire the sats and get the updated info needed for position info.
if the unit has been off for a long time or moved a long distance from where it was last turned on, it can take a while for it to come back up.
Nov 06, 2009 | Garmin GPS
Acquiring signal
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
Dec 17, 2008 | Sirius Hoods Stiletto SL100-PK1 Satellite...
ACQUIRING SIGNAL
I had the problem of "acquiring signal" after years of working. The fix is simple. The connectors on the base unit that plug into the sportster, and the antenna connector on the rear of the base get slightly oxidized. Buy radio shack electronic contact cleaner (in a can) and spray a very small amount on the male connectors (both the antenna plug and the male to female connector that is in the dock itself. Plug the antenna in and out several times and swirl it. Place the unit into the dock and remove it several times. You will likely find the signal problem is solved. You usually dont need a new antenna, but simply a clean set of contacts. Sat signals are very very suseptible to the slightest impacts. Good luck!
Jun 19, 2008 | Sirius Satellite Radio Sirius Sportster...
Not aquiring satellite signals
Press and hold the start button Booting should appear on the screen, Then loading software will show on the screen when it has finished loading release the start button and the Gps will be like new
Apr 22, 2008 | GPS
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Acquiring signal only on display
If under warranty get a replacement. If not, you are beat, they are dead when they stop getting signal and you have tried different antenna. It's sad but true.
Jan 21, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Asquiring signal
yes everyone is getting "aquiring signal" problem, why isn't sirius radio taking responsibilty ???? it's thier satttelite ??????
glenn
Nov 10, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver Logo
809 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
John
John
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
