Question about Soltek SL-75FRN2-L Motherboard
Usb I have aproblem with my usb drivers that i can't installed any device such as printer ,scanner and usb mouse and this messge appear (Usb device not recognized )
Great response MysteryFCM - Lots of thinking went into that gem.
Posted on May 29, 2008
    Scholar:
  • 187 Answers
Are the USB drivers actually present?
Posted on May 25, 2008
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Computer no longer recognizes my scanner
If you are using a multi port USB adapter that allows you to plug many devices into one USB port it may interfere with the scanner. Try uninstalling your Epson driver then download the newest one from the Epson website. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=All&x=27&y=14
Install the newest driver first then plug your scanner into a single USB port on the computer instead of the multi port.
Mar 31, 2009 | Epson Perfection V500 Flatbed Scanner
Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
Mar 25, 2009 | Canon CanoScan 4400f MultiFunction Color...
Cannot detect scanner
There is going to be issues with connecting it in this fashion. The usb adapters are not addressed the same as a real parallel port. This means that the drivers probably do not have a chance at working. The other issue is usb ports on laptops rarely have the power to drive devices larger than a mouse or keyboard. This means that the usb adaptor may not have enough power to function. Try plugging it into a powered usb hub then to the laptop. This may give it enough power to do what you want if the drivers are compatible of course.
Good Luck.
If all else fails goto goodwill and get a usb scanner. I always see stacks of them. Most are the usb type.
Feb 20, 2009 | Canon CanoScan N340P Flatbed Scanner
My printer and scanner do not work. Both are canon
Please consider and remember when the printer or the scanner did work properly. Also give a moment to note what has happened recently, before the onset of the current problem. The record will help to continue to narrow down the likely cause or causes and most quickly arrive at the solution for this problem, for these two problems.
Perhaps you have a hardware problem with a hub that connects the printer device and the scanner device to your PC, but lets look at and try some very basic things to try to fix the problem before even pursuing any hardware repair or hardware replacement.
First start with basics. If you have recently added camera software and a USB camera or a Firewire IEEE 1394 cabled camera, remove the camera for this trouble shooting activity, to see and try to get the printer to work again. Leave the scanner disconnected too.
Start the computer. Check to see if the device is found and is identified correctly. For the printer, see if it appears in your list of printers. On a PC, see in the Start Menu, the item Printers, or Printers and Faxes. Move your mouse pointer over it and see what message may appear. Right click on the printer and select properties. See the condition of the printer. After you have right mouse clicked with your ring finger, click on properties. Let's start by getting your printer to work. Maybe locate your Canon software driver installation CD, or go to www.canonusa.com/support for the driver and download it, choosing to Save it to your desktop or into C:Temp or C:Downloaded Printer Driver - Canon (if you do not know how to select the destination folder, do not select Save, simply select Install. The advantage of save before doing install is to have the driver available to make a driver CD for any other trouble shooting or computer reload activity you may want to or may need to do, to get the printer working sometime again in the future.) The ways to fix the printer problem include first, simply disconnecting the printer, then reconnecting it to the PC, and checking to be sure the printer is powered on, is online, not offline, and is actually well connected properly to the computer. The next thing to try will either be to delete the printer from the Printers in the computer and then to readd the printer. The driver will be needed so it is very helpful to have the driver installation CD or the downloaded driver - it is necessary in many situations, but some printers have drivers included in the Windows 2000 or Windows XP Home or Windows XP Professional or Microsoft Vista operating system. Best to have the newest correct driver from the manufacturer website before deleting your printer, and then proceed to delete and readd the printer. Your printer may have a flashing indicator light, a blinking that you can match up to a solution in the printer user manual or printer operator manual or the printer manufacturer's printer troubleshooting and support website. The small display screen may indicate the printer is offline because of a paper jam or because the ink supply has run out. Resolve any problem with the printer. See if this fixes the printer problem. Then proceed to add the scanner, or disconnect and reconnect the scanner, or download the driver or locate the manufacturer supplied scanner software installation CD and drivers that are needed for your computer to run the scanner. Sometimes you will find that you can set up the printer and the scanner to work directly to the printer, and then after working properly, disconnect the cable and connect the printer USB cable to the USB hub. Do the same steps to get your scanner working with it connected directly to the computer, then try to connect it to the USB hub and shut down the computer and restart the computer, and see if all is resolved by these steps.
Jul 21, 2008 | Office Equipment & Supplies
Usb host controller
There are no drivers to install if you are not using Windows98 but are using an OS that is more recent. As to adding devices to your USB ports and those devices, such as a printer, needed to be attached to the port in a a proper sequence... usually after the software is installed and the software instructs you to do so. Same goes for the Scanner and the Mouse.
What to do? Uninstall the software for those devices, un-attach them from your system. Reboot and then install the software first and when instructed to do so attach the USB cable to a port. Do that for each device and reboot first if asked to before proceeding to the next device.
Regards,
Worldvet
May 21, 2008 | Soltek SL-75FRN2-L Motherboard
No drivers found
If it is not installed properly and working there should be a yellow triangle with an exclamation mark inside it next to the scanner name.
Whatever it says, right click on it and select 'Uninstall' and allow it to be uninstalled.
Once windows appears and is ready to use, re-install the scanner driver do not plug in the scanner yet!.
Once it has finished installing, re-connect the scanner USB lead.
Windows should install the drivers and tell you the scanner is ready to use.
Apr 24, 2008 | Canon CanoScan 4400f MultiFunction Color...
Hp 4215-v officejet printer.. scanner functions not installed
For those folks who have Windows 7...
Click start from menu (bottom left of window pane),
Click "Devices and Printers",
Click on the HP printer listed,
Click "scan a document or picture"...
CALL IT DONE!!!! Gotta LOVE Windows 7...EASY!
Feb 12, 2008 | HP Officejet 4215v All-in-One Printer
Soltek SL-75FRN2-L Motherboard Logo
69 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
Steven Wander
Steven Wander
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
