Question about Canon PIXMA MP600 all-In-One InkJet Printer
Envelope printing where do you place the envelope in the printer
    Genius:
  • 1,224 Answers
There is a slider for paper on the paper tray the envelope runs long ways usually on the right hand side of the paper tray
if the slider isnt there it probably broke off this helps keeps alignment of envelope and different size papers in line
Posted on May 21, 2008
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
HOW DO I PRINT AN ENVELOPE ON THE IMAGE RUNNER 3025
On right sideway of machine is door, on this door is bypass tray wich you need to open.Open and place envelopes on it, use paper side guidances, envelope must be print side face down.
"Tell" the machine wich is format, type and confirm.
Under printer driver set according settings.
May 14, 2010 | Canon ImageRunner 3025 Black and White...
Printer prints ldocuments but will not print
In Word you create the envelop, specifying the dimensions and the way you will load it (face up or face down). Then you remove the sheets of paper and place a stack of envelops, and adjust the feeder so that the envelops won't drift while they are being fed.
Hope it helps
Aug 30, 2009 | Dell Office Equipment & Supplies
Where can I get instruction to print envelopes on Dell Printer 962?
It's not rocket science, place the envelope(s) in the tray, and adjust the guides so they're snug, and print the envelope from your "envelopes and mailings" (within MS office program) or whatever you 'mail program' you use.
I suggest to run a test or two, with a sheet of paper cut in half, (so it's the same size as your #10 envelope) to make sure you have it placed in the proper orientation- same with ANY printer.
May 17, 2009 | Dell 962 Photo All-In-One InkJet Printer
Printing envelopes 4" x 91/2"
when you print envelopes you will have to select the paper size in the print options. There should be a pull down menu with every paper size and envelope size. Select the appropriate one, and be sure the envelopes are placed the right way when you feed them in. Most home printers work best when you manually feed the envelopes in. Its a tricky process, and you may have a few jams.
Feb 10, 2009 | HP DeskJet 9800 InkJet Printer
Printing envelopes
You have to either use the MP Feeder or an Envelope Feeder. When you send the job to the "Manual Envelope" option, it will beep and prompt before each envelope is printed. Same will happen when you use the "Manual Paper" option.
You will have a hard time printing 1000 envelopes. The printer will print a rated engine speeed for the first 6-10...After that, the narrow media sensor will force the printer to slow down and you will proabably get 5-6 envelopes printed per minute.
Sep 18, 2008 | Lexmark T644 Laser Printer
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
Printing envelopes
well there is a special place wher you place your papers
and there is a small picture shown the way you put the envelope
next, on the tray botom right on the printer icon press left and press layout and scroll down the paper size manu
cos
May 23, 2008 | HP DeskJet 5550 InkJet Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Printing envelopes
Print on the Envelopes
  1. Click File , then click Print .
  2. Click Properties , then click the Features tab.
  3. Change the orientation to Landscape and the paper size to envelope #10 .
  4. Click OK .
  5. Click OK again to print.
Nov 18, 2007 | HP PSC 2410 All-In-One InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
612 people viewed this question
old marine
old marine
