Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WD440 1400 Spin
Machine not draining water, and lights including the on button flashes continually. I have checked the actual drain horse not blocked. Manual does not seem to help.
  • 2 more comments
  • Neno yokha May 22, 2008
    Thank you. There was a blockage at the junction between drain hose & pipe, now solved and washing machine working well.
  • Patsy1976 May 22, 2008
    Mine seems to be doing much the same, but it will not drain or spin or dry. I have drained the water off by disconnecting the outlet hose and managed to get my trapped washing out but still no joy with the machine actually pumping water out itself! Machine is only two years old and has broken down once already. Very reluctant to pay Hotpoint £90 if there is something I can do myself.
  • Anonymous Sep 23, 2008
    it doesnt seem to know when to stop, i've tried everything, once it went for 9 hrs before i had to turn it off to take everything out. Its 3 months old, wat do i do to make it run on a normal cycle
  • nooger Oct 05, 2008
    I have a WD440 1400 spin also. The On/off switch flashes quickly and the Drying High Heat and Reduce Creases flash at a slower rate. Any help in solving this problem would be appreciated.
    Genius:
  • 1,224 Answers
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
Posted on May 21, 2008
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
When the wash is finished it doesnt drain the
 Make sure that there is no blockage in the drain hose and that it is not kinked.  Is the drain hose installed correctly?  If you have connected your machine to a sink waste system, make sure that you have cut out the membrane from the under sink drainage system.
 Ensure that the drainage system, standpipe or under sink connection is free from any blockage. - If any of the above are found to be the cause of your problem you will need to run the machine through a spin only programme.  If you have chosen ‘Rinse Hold’, the light will flash until you press the ‘Rinse Hold’ button to continue the programme.
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have the hotpoint BWM129 super silent 1200 spin, recently the machine has stopped draining water even after spin cycle has finished , I also have constantly flashing lights which are super wash and delay...
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Feb 18, 2009 | Hotpoint BWM12 Front Load Washer
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint washer dryer BWD 129 stopped and won't drain or spin
unplug for 40 minutes in an attempt to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
862 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
