Question about Toshiba Satellite A135-S2276 Notebook
Bios Update failure
I have a problem with start up of my pc Toshiba Satellite A135-S2276
update of the bios was cut & the pc shutdown without warning
and now it not work at all only the light power botton turn on
  • Robert_gmm May 21, 2008
    10x for ur help
    the problem began on start of the pc when the windows logon appear i hear a little sound from the speaker & the pc block and the touchpad & mouse dont work . for suhtdown i press the power botton for 7 sec.
    when i enter to the bios setup (F2) on start up after about 10sec i hear the soun again from the speaker & the pc block.
    then i try to install a newer version of bios (V1.4) from cd , the update work normal till a little time then i hear the sound again & it shutdown immediatly
Hlo sir My laptop soundrivers is not working solve the problem
Posted on May 21, 2008
  • 242 Answers
You're in a trouble.
If you can get to the motherboard, you could try removing the CMOS battery. This probably won't help, because most laptop CMOS is backed-up.
So you should contact Toshiba with the problem. The chip, which contains the BIOS, on the motherboad needs to be replaced with one, containing a working BIOS for your motherboard. Or your motherboard is to be replaced.
  • Thx_nb May 21, 2008
    since my solution answers your question, you might rate it FixYa.
    Thanks in advance
Trying to reboot toshiba satellite a105 s1014 but it is asking for a password
Hello there...
I've been experiencing this similar problem once and toshiba replace my motherboard because they cannot solve the problem.
And I really hope that I am wrong. But, this problem is actually a known BIOS problem in some version of BIOS which is fixed in the latest BIOS update release Version 2.30.
See this quoted from toshiba tech support website:
Change History
Version 2.30 - 2008-10-10
  • Corrected: A BIOS password may be set automatically (spontaneously) by the computer.
  • Corrected: The internal keyboard repeat speed can not be changed.
Source:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/download.jsp?soid=2188938
See if you can claim this to toshiba, because it is actually BIOS bug.
Hope this helps... :D
Mar 23, 2010 | Toshiba Satellite A135-S2276 Notebook
USB ports do not work but diagnostic shows no problem
Hi there
if you are familiar with getting into bios go into bios and go to periphials and scroll down to where it says usb and make sure that it is enabled ok please let me know if this works for you
best regards mike
Feb 17, 2009 | Toshiba Satellite A135-S2276 Notebook
I need to update how can i phoenix bios set up utility for toshiba
Hi, which is the problem that there presents your equipment, for which you need to update the BIOS, I can make you come BIOS's last version for your equipment, only you must facilitate to me an e-mail and the Part or Model of your Machine.
Dec 31, 2008 | Toshiba Satellite A135-S2276 Notebook
Screen goes black
There have been numerous issues with Toshiba Power saving settings on laptops that can cause the same problem. Sometimes a simple BIOS update will fix it. BEWARE: Updating the BIOS can kill the motherboard because your overwriting the core logic function of it.
Before you update make sure you have a fully charged battery to prevent a power outage from interrupting the process (usually the only thing you need to worry about). Go to toshiba.com and search for your model of laptop. Look for a BIOS update. Read their instructions thoroughly, then carefully follow them.
If you purchased it from Best Buy and are under a Performance Service Plan or even Manufacturers warranty (1 yr) then take it to Geek Squad, and let them get this shipped off and done for you.
-Mark
Jun 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Default bios password toshiba satellite a135-s2276
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jun 03, 2008 | Toshiba Satellite A135 Notebook
Resetting the bios password for toshiba laptop
Your bios must be updated before
anyway u can reset the password
if ur laptop is Toshiba Satellite A135-S2276
shutdown the pc
close the screen
turn it in the back
there is a cover on the middel of the back (between left and right paper) exactly on the mid,open the crew to open this cover,its for the memory of ur pc.
remove those 2 plack (memory) than remove the plastic frome the bord,u will find on the left down 2 thing like U & I join those 2 for 3 sec or more,with any metalic think,then connect the memory / cover/creaw & turn on the pc then it wil ask to press F1 or F2 press F1 , it work
dont forget to update ur bios
Robert (for more info c_robert@live.com)
May 21, 2008 | Toshiba Satellite A135-S2276 Notebook
USB not working after resetting bios on toshiba a135
try using other usb port,,, .. run device manager and remove auknown device file... restart the computer...and also go to the cmos bios and find usb configuration the enable it..
Mar 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba
You can download the BIOS version 1.40 from the following link: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1863789&moid=1596138&rpn=PSAD6U&BV_SessionID=@@@@0051578368.1204683887@@@@&BV_EngineID=cccfadedhhhddemcgfkceghdgngdgnn.0&ct=SB&all_docs=false
The solution to this problem is to flash (update) the BIOS.
Hope this helps. Kindly leave a rating.
Mar 05, 2008 | Toshiba Satellite A135-S2276 Notebook
Reset Toshiba Labtop A135-S2276 Bios Password
see the below post for a possible solution http://www.fixya.com/support/t187128-toshiba_m105_s3004_bios_password
Aug 28, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
